| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I'm building a manually-operated (no leadscrew) positioning assembly using 2 end-supported round shafts and 4 closed Pacific Simplicity bearings. What is the best way for me to lock the carriage to the rails? thanks |
| I am just working with a company designing a machine doing a similar operation, the carriage had to be clamped due to a hydraulic ram being used to oppose/clamp a part. To visualize, the clamp consisted of a cylinder that was sleeved with material similar to a Simplicity composite lined bearing, but split in half from end to end. these were then used in two half round shells that were hinged on one side, on the other a small short stroke hydraulic or pneumatic cylinder is used to clamp the opposing side. One on each side was integrated into the carriage. The clamp cylinder travel is extremely short. This resulted in sufficient clamp force, but did not mar the surface of the rods. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 03-08-2010 at 01:13 PM. |
patriqq, esdios had a good suggestion, call the 800 # and ask for Dave H. PBC does not currently offer a brake for a configuration such as you describe, but they offer a cam lock brake on the Uni-Guide system that you may be able to mimic. sonic19 |
| Zimmer has round shaft clamp called HKR http://www.zimmer-gmbh.de/index_en.p...emente_manuell not sure who is the rep for them in US. |
| Need Help!- How do i get the Fadal to show my zero position instead of its home position? | DSUDS | Fadal | 4 | 10-28-2009 12:39 AM |
| Carriage Wheel | bling59 | General Metalwork Discussion | 3 | 06-16-2009 10:57 AM |
| Need Help!- Carriage Jam | jroma1 | Mini Lathe | 0 | 06-30-2008 10:05 PM |
| cleaning up carriage casting | guynamedbathgat | Mini Lathe | 7 | 01-02-2008 07:03 PM |
| Questions on Z Carriage | Goran321 | Joes CNC Model 2006 | 3 | 12-19-2007 08:21 PM |
