Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-21-2005, 08:23 PM
space_case is on a distinguished road
Sources for Lead Nut Mechanism
I am look for a ah, well, you see I don't quite no what to call it.
The drive mechanism for a stationary lead screw design.
The whole assembly (including gearing) between the stepper
and up to and including the (hopefully anti-backlash)
lead nut.
I don't know what to call it nor do I know where to find it.
Any suggestions for COT equipment of this sort?
Or am I stuck with fabing it up myself?
Old 04-21-2005, 08:45 PM
ger21's Avatar
Your'e talking about a rotating nut? A while back, a website for one of the low cost commercial machines (can't remember which) listed a rotating ballnut assembly. The price was around $800-$900, I think. It included the nut, belt drive and motor mount. But I haven't ben able to find it again.
Old 04-21-2005, 08:46 PM
kevincnc is on a distinguished road
It sounds like you're looking to rotate the nut ("rotating nut" assembly.) I have designed several of these to get longer strokes without ballscrew whip. THK and others make a rotating ballnut assembly with a flange for attaching a pulley and one for anchoring to the thrust bearing to the carriage. They're extremely expensive, you'll probably want to make your own.
Kevin
Old 04-21-2005, 08:58 PM
This is what I figured. I guess it's off to the old drawing board.
What about a source for "accurate" pulleys. I am concerned about the 'true' ratio of the pulleys. I know I can take measurements once I am up and running, and back it out in the software; but I want to be on the money from the get go.
So now my questions turn to...
Sources for pulleys? Belts?
I am looking at ~450oz steppers, so where can I find adapters for the motor shaft to the pulley?
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
anti backlash nut? sixpence DIY-CNC Router Table Machines 13 07-18-2007 02:51 PM
Ab Acme Nut??? MMT CNC Plasma and Waterjet Machines 0 02-27-2005 09:53 PM
Leadscrew backlash nut issue. jaydee116 General Metal Working Machines 5 12-13-2004 07:57 PM
Nut wear avsfan733 DIY-CNC Router Table Machines 6 12-18-2003 06:14 PM
