Math help please
Results 1 to 5 of 5
Thread: Math help please
    Jan 2017
    Default Math help please
    Finishing up my CNC conversion. X and Y all set but need help with Z. Here is what I have.
    1. Stepper motor 5000 steps per revolution.
    2. .200 pitch ball screw so 25000 steps = 1”
    3 20 tooth timing gear @ 1.500 wide on motor
    4 20 tooth timing gear @ 1.200 wide on screw
    I followed Mach 4 formula I thought and did
    1.5 / 1.22 * 5000 / .200 = steps however I’m doing something wrong because it’s off a little and gains the more I go. Can you help me out and show me how you came up with it? The formula I see is for gears with different tooth config. My timing gears have the same amount of teeth but have different circumference. I’m measuring the pully across with a set of calipers.
    thanks
    Rick
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Math help please
    20 teeth to 20 teeth is 1:1, so you should have 25,000 steps per inch.
    UCCNC 2017 Screenset
    Jan 2017
    I am a complete moron, thank you!
    Community Moderator wendtmk's Avatar
    Dec 2005
    How can you have the same amount of teeth but a different circumference on the timing gears? Are you sure both gears are matched with the belt you are using? That's not making sense. The teeth should be the same width with the identical separation between the teeth. For that to be so, the circumference can not be different.
    Sep 2006
    Here are a few more things to check that can cause errors in the overall steps per inch.
    1) Stepper motors are often 200 steps per revolution combined with microstepping that takes a variable number of steps per full step. I have seen microstepping values of 2X (half stepping), 4X, 10X and possibly 16X. It depends on the controller and how it is set up.
    2) Metric ballscrews could have a pitch of 2 threads per cm or 5.08 threads per inch. You would have to adjust the steps per inch slightly.
    3) Something seems off if you have a 1.5" gear and a 1.2" gear with 20 teeth each. They would either slip, or maybe one of them has a different tooth count.
    Steve
Math help please
Math help please
