Selecting the right ball screw Size and system - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Selecting the right ball screw Size and system
  1. #21
    May 2011
    Default Re: Selecting the right ball screw Size and system
    If you want a machine to perform , then you have to have a good selection of components, the machine in these videos, was built for speed and high production, both where achieved, the cost was high for the machine build, the machine payed for it's self in less than a year, that was 5 years ago, it now has multiple tool change racks and 2 ATC Spindles
    This Home built machine here can run 2500 IPM Rapids and runs 3D easy at 600IPM cutting
    That's a nice machine. Is it your build?
    Is that a single pinion system using servos and gear reduction?
    I'd like to see the system from Damencnc using nema 34's do the 500 IPM 3D carving and 800 IPM rapids. That was my point, to validate the performance of that specific system. I believe comparable systems, for example, from CNCRP, are capable of that, but at the same time are certainly a step down from the all steel, servo driven machine that you have posted videos of.
    Although, your post is definitely relevant for the OP who is thinking of using ballscrews for a huge router.
    For a large wood working machine, I don't see a problem with a single pinion R&P system to give good performance. On a budget, perhaps he should spend his money on motor upgrades to servos and planetary gear reducers on a single pinion R&P system than to pursue a rotating nut design using stepper motors or even the expensive damencnc double pinion system? Tell us your thoughts.
  2. #22
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by NIC 77 View Post
    It has a single pinion, Precision Ground Helical Rack 1Kw Ac servos 20Bit Encoders ( 1,048,576 ppr ) the machine Table is 12' X 6' of Travel
    Mactec54
  3. #23
    Jan 2005
    NIC 77
    Here is a photo of the Helical Pinion and lubricator, on that machine, this is what you need if you want / need accuracy and performance
    Attached Thumbnails Attached Thumbnails Selecting the right ball screw Size and system-pinion-jpg
    Mactec54
  4. #24
    May 2011
    That is quite the pinion! Obviously those are flange mount planetary reducers?
    Is this system spring loaded or just carefully aligned?
    I've never seen something like that before with the lubrication. Thanks for sharing.
  5. #25
    Jan 2005
    I thought it would be interesting to show what a high quality pinion setup is like, No spring loading, you can not spring load a Helical Rack, It was all aligned with an indicator, the Racks where fitted on a machined surface, straight and parallel within .001 over 12' along with the Linear rails
    Mactec54
  6. #26
    Jan 2017
    United Arab Emirates
    Hi there
    I am thankful of all you experts regarding your most helpful replies.
    It took me a while to read them all,
    I think I can conclude that the best system for over a meter long travel is the R&P systems.
    But that backlash is the most challenging issue.
    What do you think a bout Split Pinion design?
    Double pinion, well I am not so sure since apparently it is not that common, and we just do not know much about them,
    also NIC77 I agree with you on 1:5 ratio it is much better choice.
    How about the Belt driven System? would you recommend it for my 2m*4m table?
    Finally Mactec54 : Apparently your machine is single pinion with ac Servo Motor, Do you have a gear box of some sort with your servo?
    Could you briefly explain it? and if you are not spring loading it, then how do you mounted on your Rack? have you just lay it on the rack?
    Or do you some how tension mounting it on the rack?
    Regards
    johnansaro
  7. #27
    Jan 2005
    Quote Originally Posted by johnansaro View Post
    Hi there
    Regards
    johnansaro
    This machine is not mine, I just helped with the build
    Yes there are Gearboxes 10:1 on this machine, the AC Servo run up to 6,000 RPM
    The Racks are Helical Heat treated and precision Ground, every part is precisely mounted on the machine so there is no problem with backlash
    There is no spring loading, just precise alignment, you can not use any kind of spring loading device, when using a Helical Rack and Pinion
    The Racks are mounted on a machined surface, Matching the Linear Rails, that has a machined Edge for the Rack to be clamped against to get precise alignment the full 12' , the alignment of the Racks were within .001" over the 12' length
    No Belt Drive, would not be suitable for a machine this big
    Most use straight cut Racks, these you can spring load the Pinion, or use more than one Pinion to help with the backlash
    Rack and Pinion is the only worth while way at this time, even the Precision Helical Rack is cheaper than a BallScrew for this size machine, I'm working on a system for any type of router build, that will fill the void if it is successful, it is some time away before it will be for sale
    Mactec54
  8. #28
    Jan 2017
    Hi there
    Mactec54 : many Thanks for your prompt reply.
    But as you know machining such large or long Piece (about 4 meter Long) is not easy and cheap.
    How about if my table is made of steel tubes, and then can I use aluminium profile in order to install the racks?
    Basically this is the scenario, steel tube then aluminium profile and then rack and rail on them
    Also you mentioned that "
    you can not use any kind of spring loading device, when using a Helical Rack and Pinion"
    could you explain on it, Since the machine that I made, I am spring loading my system, and the rack and pinion is Helical.
    I am attaching a picture, and video from it. (It seems that I can not upload the video since it is in my computer)
    By the way what I am cutting is a musical instrument.
    Finally sometimes when i am cutting, it smokes a lot and turns the piece to brownish or blackish color.
    What could be the probable cause? My speed during cutting is 40 mm/sec, and spindle is 15000 rev/min.
    regards
    johnansaro
    Attached Thumbnails Attached Thumbnails Selecting the right ball screw Size and system-20170718_104100-jpg
  9. #29
    Jan 2005
    Hi there
    regards
    johnansaro
    What happens with a Helical Rack is in one direction the Pinion gets pulled into the rack, and in the other direction the pinion is trying to be pushed away, so it would be hard to have a spring loaded system work correctly in both directions
    Mactec54
  10. #30
    Jan 2017
    Hi there
    many thanks for your reply.
    But Mactec54 , could you also comment on me using aluminum profile rather than using a flat then precision machining it?
    Is this a good idea or not?
    Also lubricating the rack and pinion, is it a mandatory procedure or an optional one?
    regards
    johnansaro
  11. #31
    Jan 2005
    Hi there
    regards
    johnansaro
    Anything that has metal to metal contact, should have some form of lubrication, the wear rate would be high without any type of lubrication
    Using aluminum profile that is not machined, would be no different than using steel that is not machined, short lengths of aluminum profile 1m in length for small machines, is about the limit without machining, you can buy aluminum profile with 2 sides machined from this company, I don't know what sizes they have that are machined
    https://us.misumi-ec.com/vona2/mech/...num+Extrusions
    Mactec54
