Selecting the right ball screw Size and system - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 25
Thread: Selecting the right ball screw Size and system
  1. #13
    Jul 2017
    Default Re: Selecting the right ball screw Size and system
    Non expert here but, aiming to build the same kind and size of machine, I've been searching, reading and learning from every web resources I could find.
    Like you, in the beginning, ballscrew seemed the best way to go. In the end, my machine will use so kind of R&P system.
    The complexity and requirements (and price) rocket when you consider BS for sizes over 1,5m with high acceleration and high speed. They do in a way that if the purpose of the build is to cut wood, it barely doesn't make sense any more.
    For my project, DamenCNC's straight rack and double pinion system, discovered through RoboCNC's excellent X2 build series on YT, made me make the switch to R&P !
    I'm also considering helical R&P for best of breed choice but these again, needing an high precision ground support, raise requirements for the structure. Also, creating an axial load on the motor/gear assembly, this has to be taken into account in the design. Thus, helical R&Ps can't be directly substituted in straight R&P machine designs we can find around :/
    Hope it'll help
    Jérémie
    Envoyé de mon A0001 en utilisant Tapatalk
  2. #14
    May 2011
    ger21, does that machine use a single ballscrew on the long axis under the table or does it have two?
    Would you say the performance is any better than the rack and pinion machines you have?
    Interesting that it is a rotating ballnut but it still needs a spring loaded support in the center.
    Here's a video on Youtube
    And he posted CAD files of the parts he had to make
    https://grabcad.com/library/rotative...t-isel-25x10-1
    I still think this is not the best idea for such a large machine compared with rack and pinion, but thought you might find that interesting. You might find a couple used rotating ballnuts on EBay. For an arm and a leg.
    Also looked at a couple videos of rotating nuts on YouTube that sounded awful.
    John,
    Can we at least agree that for a machine that long, a regular ball screw with a not rotating nut is a bad idea?
  3. #15
    May 2011
    Quote Originally Posted by silopolis View Post
    Hope it'll help
    Jérémie
    That's interesting. First time I've come across this double pinion. I just skimmed through a couple of videos on the Robo CNC website.
    I'm wondering, why he's using a 10:1worm reduction on a stepper motor for rack and pinion? What is the radius of the pinions, they look quite large? Do you know what the overall machine travel is per rotation of the motor? Any mention of backlash on the worm gear? Hmmm, you know, you could do the same thing, 2 pinions, with belt gearing instead of a worm gear on the other side (but not at 10:1, like 2:1 or 3:1)
    I couldn't find any videos of the thing actually running or what speeds and accels they are getting. Also, I didn't notice any spring loading but I may have missed it.
    I will reserve final judgement until I see the thing actually running around cutting, and hear some user reviews, but definitely interesting. Thanks for sharing.
    Perhaps John should just buy the parts from robo CNC and do a kit build, sourcing the rails and T slot from whoever is closest / least expensive for him.
    Of course, a single pinion for each motor works fine.
  4. #16
    Mar 2003
    Just one. It's a cantilevered gantry that's open on the front side of the machine. It's a 6ft gantry beam, about 18"x18", made of bent and welded 1/4" plate, to form a tube, with the ends capped.
    Just to keep it from sagging when the machine is parked at the home position. It doesn't do a lot.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  5. #17
    Jul 2017
    Quote Originally Posted by NIC 77 View Post
    For those interested:
    * RoboCNC X2 page: https://www.robocnc.nl/?page_id=5300
    * RoboCNC X2 build YT playlist: https://m.youtube.com/playlist?list=...yCkJLcRBChdojC
    * DamenCNC Worm Gearboxes: https://www.damencnc.com/products/me...404_w_75__GB_1
    * DamenCNC linear motion modules: https://www.damencnc.com/products/mo...404_w_72__GB_1
    * DamenCNC RTR kits: https://www.damencnc.com/products/ma...04_w_340__GB_1
    Seems to be the recommended ratio by DamenCNC for high loads, vs 5:1 for light loads
    Can't remember, but pretty sure Marcel mentions all these infos in his detailed videos
    For the gearbox backlash, from the V30 i spec:
    * 8 arcmin or less on reduced backlash models (no load conditions)
    * 8 arcmin or more on normal backlash models
    I know Marcel has been busy since his last video but came back lately to announce follow ups soon... Agreed I'd love DamenCNC to have demo videos, and will surely suggest them to make some in my next message. As they invited me to visit them to see a machine running, I may end up filming it myself...
    About spring loading, I have to watch Marcel's worm gear assembly and mount videos again...
    You're welcome As told, ain't no guru here and so, all opinions, PoV and constructive criticisms are very welcome and looked for.
    Parts, modules and kits should be bought from DamenCNC.com. Don't hesitate to contact them for further informations and advices, they're very competent and willing to help Selecting the right ball screw Size and system
    Of course, but in this case I'd love to find a solution to build a structure suited for helical R&Ps
  6. #18
    Jul 2017
    I will reserve final judgement until I see the thing actually running around cutting,...
    Only video I could find is here
    And here is the link to the R&P anti-backlash assembly: https://www.damencnc.com/products/me..._w_74_554_GB_1
    There's no spring loading of the pinions on the rack, but you'll see slots for adjustment. Could be modified to add spring loading I think
  7. #19
    May 2011
    I see, you can use either a 5:1 or 10:1 worm gear.
    https://www.damencnc.com/products/me...w_74_247_GB_1#
    Oh, I see, the 15T pinion has an effective diameter of 30mm.
    8 arcminutes of backlash is (8/60) = 0.133 degrees
    (2 x pie x 15mm) x (0.133 / 360) = 0.035 mm = 0.0014" backlash from the worm gear. So not too much, but more than a thousandth. Perhaps more on the non reduced backlash model.
    It seems to me like the 5:1 is a better choice. 10:1 is too much for a stepper.
    https://www.damencnc.com/userdata/fi..._Ghirri_MV.pdf
    So if we look at page 18, the efficiency of the 5:1 MV40 is 76% and for the 10:1 MV40 is 69%. Did I misread that somehow? That's really bad. A typical planetary gear is around 94% I believe.
    Also, I could not find the gear output inertia listed. That's needed for acceleration calculations. Do you know where to find it?
    So 160 Euros for the gear + 270 Euros for the two pinion system + VAT = 430 Euros + VAT = 514.22 USD + 103 USD VAT @20% (not sure if you have to pay this if you live in another country, instead, probably customs and import to your country.) That's pretty expensive.
    I would like to see the video of doing a 3d carving in wood at 500 IPM with 800 IPM rapids.
    The double pinion system might have merit, but at this point, I'm not convinced in this particular system.
  8. #20
    Gold Member
    Jan 2005
    If you want a machine to perform , then you have to have a good selection of components, the machine in these videos, was built for speed and high production, both where achieved, the cost was high for the machine build, the machine payed for it's self in less than a year, that was 5 years ago, it now has multiple tool change racks and 2 ATC Spindles
    This Home built machine here can run 2500 IPM Rapids and runs 3D easy at 600IPM cutting
    , it was running at 500 IPM in this Video cutting
    Mactec54
  9. #21
    May 2011
    That's a nice machine. Is it your build?
    Is that a single pinion system using servos and gear reduction?
    I'd like to see the system from Damencnc using nema 34's do the 500 IPM 3D carving and 800 IPM rapids. That was my point, to validate the performance of that specific system. I believe comparable systems, for example, from CNCRP, are capable of that, but at the same time are certainly a step down from the all steel, servo driven machine that you have posted videos of.
    Although, your post is definitely relevant for the OP who is thinking of using ballscrews for a huge router.
    For a large wood working machine, I don't see a problem with a single pinion R&P system to give good performance. On a budget, perhaps he should spend his money on motor upgrades to servos and planetary gear reducers on a single pinion R&P system than to pursue a rotating nut design using stepper motors or even the expensive damencnc double pinion system? Tell us your thoughts.
  10. #22
    Gold Member
    Jan 2005
    It has a single pinion, Precision Ground Helical Rack 1Kw Ac servos 20Bit Encoders ( 1,048,576 ppr ) the machine Table is 12' X 6' of Travel
    Mactec54
  11. #23
    Gold Member
    Jan 2005
    NIC 77
    Here is a photo of the Helical Pinion and lubricator, on that machine, this is what you need if you want / need accuracy and performance
    Attached Thumbnails Attached Thumbnails Selecting the right ball screw Size and system-pinion-jpg
    Mactec54
  12. #24
    May 2011
    That is quite the pinion! Obviously those are flange mount planetary reducers?
    Is this system spring loaded or just carefully aligned?
    I've never seen something like that before with the lubrication. Thanks for sharing.
