It's not about accuracy, but rather stiffness.Can I get a decent accuracy for woodworking with 15mm belts, and do I need wider belts ?
What kind of error's are made by belts so they are not good for wood router?
Do I need Belt on Belt system ? (how much of improvement is that on the acuraccy)
The Momus is a small machine, that does light cutting, so it can get by with belts. But as the machine gets bigger, heavier, and faster, the belts start to flex, which can affect the quality of the cut.
Belt on belt systems can be much stiffer.
