I have 5/8in (0.625in = 15.875mm) precision rod. Unfortunately, SAE guides are expensive and difficult to come by in 5/8 size. Can I use 16mm guides instead? I am not looking for an ultimate precision 0.1mm is OK (woodworking). Noise and super smooth motion is not a major concern as well as long as steppers will push it along and will not jam. I am just wondering if this is going to fail mechanically because of slightly larger space between the guide and the rail or if there are any other considerations. Thank you.
