Linear and Rotary Motion
Page 1 of 117 12341151101 ... LastLast
Threads 1 to 20 of 2326
Forum: Linear and Rotary Motion
Discuss ball/Acme screws, R&P, linear slides and theory here.
  1. Sticky Threads
  2. Sticky Thread Sticky: Ballscrew Basics
    Started by Swede‎, 03-01-2005 12:06 PM
    10 Pages
    1 2 3 4 5 ... 10
    07-29-2017, 02:25 AM Go to last post
  3. Poll Sticky Thread Sticky: Poll: Screw Threads 101
    Started by widgitmaster‎, 05-20-2006 10:37 AM
    5 Pages
    1 2 3 4 5
    07-01-2015, 09:48 PM Go to last post
  4. Sticky Thread Sticky: Servo or Stepper for CNC?
    Started by CNC_Kid‎, 02-05-2006 03:37 PM
    5 Pages
    1 2 3 4 5
    cnc, cutting, plasma, run, servo, wan
    02-08-2013, 03:27 PM Go to last post
  5. Sticky Thread Sticky: Linear Motion F A Q compilation. Please read before posting.
    Started by svenakela‎, 02-28-2007 06:52 PM
    04-01-2011, 05:59 PM Go to last post
  6. Forum Threads
  1. Will these bearings work?
    Started by adam_m‎, 02-22-2018 08:21 PM
    adam, compatibility, hsr20, identify, thk
    Yesterday, 10:39 PM Go to last post
  2. Need Help!- Wondering about cheap chinese linear rails
    Started by Dactyl‎, 02-22-2018 11:25 PM
    cheap, china, chinese, guide, rail
    Yesterday, 10:43 AM Go to last post
  3. shaft mounts on supported rails
    Started by greenene‎, 02-22-2018 09:06 AM
    fair, mounts, shaft, shafts, supported
    02-22-2018, 03:57 PM Go to last post
  4. Ballscrew supported-end bearing
    Started by amowry‎, 02-12-2018 04:46 PM
    ballscrew, bearing, end, preloaded, screws
    02-22-2018, 12:51 AM Go to last post
  5. homemade ballscrew
    Started by llilrex‎, 01-06-2018 11:08 PM
    02-19-2018, 07:39 AM Go to last post
  6. Best belts for 750w servos and 1.8kw spindle? Mill retrofit
    Started by j3dprints‎, 02-16-2018 04:03 AM
    2 Pages
    1 2
    02-17-2018, 01:23 PM Go to last post
  7. location of ballscrew
    Started by greenene‎, 02-16-2018 07:37 AM
    ballscrew, case, distance, rail, rails
    02-17-2018, 03:57 AM Go to last post
  8. Need Help!- advice pls
    Started by wm4mm‎, 02-15-2018 05:55 PM
    02-15-2018, 05:55 PM Go to last post
  9. Reading data charts correctly-- linear slides
    Started by greenene‎, 02-09-2018 04:53 AM
    02-14-2018, 08:20 PM Go to last post
  10. Rack and Pinion Calculations
    Started by thegolfer‎, 01-07-2013 11:00 PM
    2 Pages
    1 2
    02-12-2018, 03:57 AM Go to last post
  11. Slaved Axis timing belt safety back up
    Started by gabalaz‎, 02-05-2018 09:58 AM
    belt, drive, motors, slaved, timing
    02-06-2018, 03:32 PM Go to last post
  12. Need Help!- Timing Pullys
    Started by racewayron‎, 01-25-2018 05:54 PM
    14mm, bore, center, pullys, timing
    01-26-2018, 11:39 AM Go to last post
  13. Time to go from Delrin Nut to Ball Screw?
    Started by justCNCit‎, 01-21-2018 02:04 AM
    01-21-2018, 07:57 PM Go to last post
  14. Linear Rails... inexpensive
    Started by adam_m‎, 01-20-2018 08:43 AM
    gold, inexpensive, linear, priced, rails
    01-20-2018, 09:42 AM Go to last post
  15. How bad are these Chinese ballscrews gonna be?
    Started by QuinnSjoblom‎, 01-19-2018 11:31 AM
    backlash, ballscrews, force, inserts, software
    01-19-2018, 02:57 PM Go to last post
  16. Need Help!- Whats meant by Module 1.5 and 1.0 when referring to rack (and pinion)?
    Started by Merlysys‎, 01-14-2018 08:50 PM
    cnc, module, pinion, rack, router
    01-15-2018, 08:20 AM Go to last post
  17. Headache trying to understand the picture...
    Started by saslanis‎, 01-12-2018 06:49 PM
    bk/bf, gap, picture, profile, sbr16
    01-12-2018, 06:49 PM Go to last post
  18. How to attach a HTD pulley to shaft firmly
    Started by suspension‎, 12-10-2017 05:40 PM
    attach, htd, methods, pulley, shaft
    01-12-2018, 02:41 AM Go to last post
  19. Quality of MISUMI Linear Ball Bushings
    Started by jarjar‎, 01-03-2018 01:26 PM
    ball, bushing, linear, misumi, quality
    01-11-2018, 01:23 PM Go to last post
  20. Importance of ball screw pitch size
    Started by Goemon‎, 12-25-2017 03:35 PM
    3 Pages
    1 2 3
    01-09-2018, 07:03 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 26 users browsing this forum. (0 members & 26 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
