Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-18-2010, 05:27 AM
nokillzone's Avatar
nokillzone is on a distinguished road
Wink Stupid question
If i get a laser tube of 60W and a power supply of 40W Lets say.
Will that extend the life of the tube?
Planing of building a laser engraver and using
DSP CO2 Laser Engraving/ Cutter Controller. Support CorelDraw & AutoCad
Code:
http://www.lightobject.com/DSP-CO2-Laser-Engraving-Cutter-Controller-Support-CorelDraw-AutoCad-P321.aspx
Don't know how hard will it be to wire it all up.
Hope i hear some good feedback.
Thanks!
Old 02-18-2010, 09:51 AM
nobacoutinho is on a distinguished road
I am in this doubty too....
" If i get a laser tube of 60W and a power supply of 40W Lets say.
Will that extend the life of the tube? "
Old 02-18-2010, 10:21 AM
zax15uk is on a distinguished road
Only a fool answers a stupid question - so here goes.
Buying a 60W tube and 60W PSU and running the laser at less than full power (reduced pulse width) will significantly increase the tube life over running it at 100%. This is true with any laser, diodes or gas tubes.
I'm not sure if the trigger / tickle requirements are the same between the 40 and 60W tubes but I suspect not, in which case you'll either get no output (it won't fire) or you'll stress the PSU and cause it to fail earlier.
Zax.
P.S. it wasn't really a stupid question... so I guess that doesn't make me a fool
Old 02-18-2010, 06:31 PM
nokillzone's Avatar
So one should always try to buy matching power supply and a laser tube?
or buy a 60W system but run it less than 70% ?
Would that slightly extend its life span??
Old 02-19-2010, 11:59 AM
Most power supplies are suitable for several power levels, for example you can buy a PSU which is rated for 40, 60 and 80W tubes. This is ok.
If you run any laser at reduced power it will last much longer.
If you need 40W for cutting, buy a 60W instead of pushing a 40W at 100% duty cycle.
Zax.
Old 02-19-2010, 03:46 PM
nokillzone's Avatar
Thanks .. id realy like to make this happen. been thinking about it for soo long now ..
and with what this controler dose i like seems easy.
New Machine Build- Maybe a stupid question haroldj Stepper Motors and Drives 1 04-24-2008 01:17 PM
probably a stupid question mad.sculpture Linear and Rotary Motion 4 10-09-2007 04:55 PM
Another stupid question? t305100 General CNC (Mill and Lathe) Control Software (NC) 15 09-03-2006 08:01 PM
Stupid Question CNCRob CNCzone Club House 2 09-04-2005 01:42 PM
stupid question boomer187um Autodesk Software (Autocad, Inventor etc) 3 08-29-2005 04:16 PM
