| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
First of all, I have no experience with lasers. Is there a cheap laser (~150EUR) that can cut 10cm thick XPS? AFAIK, there are two types of lasers: laser-diodes and real-lasers. I guess real-lasers would cut XPS with no problem but are expensive. Are laser-diodes strong enough to cut XPS? I understand that laser-diodes are better suited for engraving, because of focus problems, right? If I would somehow change the focus dynamically, would it then cut 10cm of XPS? At what speed? Thank you. |
| Short answer: No. It would be a challenge for any laser to cut 10cm (4 inches) of XPS foam. A CO2 laser and correct optics would work, but you won't get a parallel cut. Hot wire is the best method for that thickness of foam, and much cheaper too. Zax. |
| Tags |
| laser xps |
| Laser cutting eva foam | James80 | Laser Engraving & Cutting Machines | 2 | 03-27-2009 09:27 AM |
| Laser cutting craft foam, have you done it? | rpage | Laser Engraving & Cutting Machines | 2 | 03-22-2009 08:42 PM |
| Laser Cutting Foam | James80 | Laser Engraving & Cutting Machines | 3 | 03-17-2009 08:21 AM |
| Build a cheap, SIMPLE, CnC foam cutter. | moreil | CNC Wire Foam Cutter Machines | 51 | 01-04-2009 08:09 PM |
| Cheap foam for testing a CNC program | replicapro | General Metalwork Discussion | 3 | 06-09-2006 01:12 PM |
