Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-11-2010, 12:05 AM
loyedp is on a distinguished road
glass engraving problem
hi
i need help to solve problem while engraving glass, i m raster engraving on sheet of full size, my problem is that even though give less power n maximun raster speed, when i touch engraved portion, the powder of glass removes ,leading it to bad finish.Is there any solution for this prob,or can i apply some spray on glass so tht i dnt get bad finish even if i touch.
Old 02-11-2010, 03:25 AM
Litografa's Avatar
Litografa is on a distinguished road
Try to engrave thru wet newspaper
Old 02-11-2010, 08:44 AM
SkipW is on a distinguished road
I've had good results using a thin coating of liquid dish soap on the glass before engraving. You may still get some glass residue but most comes off when you rinse off the soap after engraving.
You can go over the engraving with a shop vac and brush attachment also.
Old 02-12-2010, 08:29 AM
as it is a full sheet of glass,i feel after few minutes this wet newspaper will get dried , any way let me check it.. as it is a rastering process may be i have to change fastly to dried .. any ways thks 4 ur valid help
i wil check it
Old 02-12-2010, 08:36 AM
Litografa's Avatar
If you have a lot of work with flat glass engraving - look on our impact engraver
http://www.litografa.lt/index.php?aid=255
or if you have simple graphics - use sandblasting
Name:	GLASS DOOR.jpg‎
ID:	99873   Click image for larger version
Name:	GLASS TABLE_CARDS.jpg‎
ID:	99874   Click image for larger version
Old 02-12-2010, 04:19 PM
fantasy2 is on a distinguished road
What about oil with a low viscosity? It won't vaporise..
Old 02-12-2010, 04:28 PM
Isn't there the chance that the oil could burn?
Heh heh hmm fire! fire! fire!
Old 02-12-2010, 06:48 PM
hmm, yes you're right.
I never tried it, just a thought, but if it's a big piece of glass. Maybe first a wet paper and then cover it with that sticky plastic they use to cover food so the water can't vaporize?
Old 02-12-2010, 07:03 PM
Those are some very nice engravings. Were they done with your impact engraver?
Old 02-12-2010, 11:03 PM
I think oil is dangerous as it might hav the tendency to burn, it has a risky factior involved in this process pushing me back towards not trail out this work
  #11   Ban this user!
Old 02-13-2010, 12:53 AM
Litografa's Avatar
Yes, SkipW - done with impact.
More samples is here (you will love them but be carefull - file is about 5 Mb)
http://www.litografa.lt/picture/uplo...ples%20mid.pdf
Idea is similar with Metaza but oriented for bigger size - for example MINIMUM table size is 30x40 cm, and MAXIMUM is 80x190 cm. So honestly speaking - our equipment is not for dog tags
If we speak about impact engraving on glass, main difference from laser is that impact needle leave DOT WITH CERTAIN DEPTH (small, but depth). In this case you can add inks/paints inside and if you use pigment inks like MAIMERI - image will not fade. Laser ONLY change color/structure of glass from transparent to matt.
  #12   Ban this user!
Old 02-13-2010, 01:22 AM
bevins is on a distinguished road
Is it a special bit you use or something else about the machine thats different for engraving glass?
Need Help!- Glass Engraving SHADOW042 Laser Engraving & Cutting Machines 10 12-14-2011 05:38 AM
Engraving Glass w/ CNC mredican Glass, Plastic and Stone 12 04-28-2011 05:02 AM
Engraving and Etching on Metals, Acrylics, Glass, Plastics in New York bradpit Engraving Machines 0 08-29-2009 06:49 PM
Glass engraving julianh General Metal Working Machines 8 08-10-2009 08:10 PM
Stone-Glass engraving Aksess General CAM Discussion 3 12-23-2004 01:32 PM
