Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-20-2010, 04:03 PM
miguelver is on a distinguished road
ayuda lasercut 5.1
Hello to all I need help with lasrcut 5.1, believe a name in the program and on the display of the machine having ordered it to the machine he(she) says to me soft stop sign, the manufacturer says to me that it is a problem of measures, but I believe that I have them well.
You agradeceria that me envieis a ficrero co the extension.mol to verify, and if you to past to someone the same thing to seeing if me podeis to say something.
Thank you
Old 01-20-2010, 11:05 PM
SkipW is on a distinguished road
Soft Stop Error
http://www.cnczone.com/forums/showth...477#post571477
Here is a thread about the soft stop error. It basically means the file you are sending to the laser is bigger than your laser table size. Try a smaller file and see if that works.
Hope that helps.
Old 01-21-2010, 04:03 AM
KPBadger is on a distinguished road
Soft Stop.
Hi Miguel.
you should also look for the option "immediate" in Lasercut 5.1
(at the bottom right of the screen )
This changes whether the cutting program starts from absolute or relative position:-
unticked = absolute :-
program starts from zero/datum, position ( 0,0)
here you can run a program up the full bed size.
ticked = "immediate" / relative :-
program starts from current laser head position (x,y)
here you can not run the max size since it will exceed the limits and you get the 'soft stop' error.
Let us know what happens.
regards
KPB
Lasercut V51 - HELP! TheWorkshopGuy Laser Engraving & Cutting Machines 2 10-05-2009 05:25 AM
Need Help!- lasercut LOLO80 Laser Engraving & Cutting Machines 7 04-11-2009 07:56 AM
Lasercut 5.3 (5.2) bibi Laser Engraving & Cutting Machines 1 03-17-2009 09:42 PM
LaserCut 5.0 edsawen Laser Engraving & Cutting Machines 12 03-12-2009 11:37 PM
Ayuda con LaserCut 5.1 anibald23 Spanish CNCzone 3 08-12-2008 04:50 PM
