Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-10-2010, 02:35 PM
Magritte is on a distinguished road
The laser gods hate me
I had just aligned the mirrors properly and for the first time I actually my hx 3040 working properly! When we had to have a couple of subtle dips in the power. It finished cutting the object.
However the machine is no longer communicating with my PC. I just get com error 2. I restart it all and get no USB key. Restart it all again and this time get the com error 2 message again.
Can anyone be more specific on this error message?
I guess ones these things has died:
Serial port (hopefully)
Laser circuit board
Softdog
If its the latter 2 where can I get them from!?
Old 01-10-2010, 09:41 PM
kevinliutrade is on a distinguished road
You can try to install the software again to see if it can work again.
You can buy the two things from the person who sell you the laser machine if he is the manufacture and also ask help for them, they should be special
Old 01-12-2010, 06:00 AM
KPBadger is on a distinguished road
Communication Error.
Hi Magritte.
With my laser ( XYZ6090, lasercut 5.1, USB ) it matters which port the softdog goes into.
On the laptop computer the softdog only works in the rear ports, not the side ports.
Also, the USB cable at the machine end does not have a very good fit and sometimes it will work itself loose .
Check the plug is making a good connection.
I hope the problem is simple to fix.
regards
KpBadger
Old 01-16-2010, 12:03 PM
Thanks for help no success to report yet though. I have reinstalled newlydraw and tested the serial cable on my printer. The softdog is working because when I take it out it wont even let me load newlydraw. So it must be the circuit board I guess.
If anyone can recommend a place to get a standard to upgraded board that would be great.
FADALs hate-ers :) Konstrukter1 Fadal 41 01-17-2010 07:04 AM
I hate reamers! orionstarman General Metalwork Discussion 66 07-16-2009 10:39 AM
what I hate about my vf2 fourperf Haas Mills 12 02-25-2008 08:20 PM
I hate MDF!!!! hpghost DIY-CNC Router Table Machines 14 08-27-2007 11:59 AM
Your gonna hate me for this SMT-OPERATOR RC Robotics & Autonomous Robots 11 05-29-2007 03:17 PM
