| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Does anybody know of any laser cutter technicians, preferably in the North West of England? I have a chinese 3040 machine which isn't running properly, and i'm not confident with trying to fix it myself... Any help very welcome! |
| I'm a novice so excuse my lack of technical terms! Basically, everything was working ok with the machine, and i can't think what could have changed things, but now when i turn on the machine, the head goes upto the top left hand corner as usual, but when i start to engrave, the head moves to the right but it's as though it can't move downwards to get to the starting point. If i turn the machine on as usual, wait for the head to return to the top left corner, and then slide the head a cm or so down the Y axis and then begin to engrave the head seems free to move as it wants. It's asthough it just gets stuck at the top. The problem doesn't stop there though as now the curves don't seem to be cutting as smoothly, and a straight diagonal line can come out all wobbly, especially on a higher speed. I've tried adjusting the screws on the head and also tried adding a bit of WD40 incase that made any difference, but neither helped the situation. I'm at a loss as to what to try |
| Hi I am in the UK as well I have the same machine and had almost the same problem. If you check the timing belts and pulleys on the rails you might find that the tension of the belt has slackened causing the wobbly lines and odd curves. The adjusting screws that tighten or loosen the belt are at the end of the rails. They take a while to get right and small adjustments can make a lot of difference. If the belts are too tight this can cause a lot of vibration/noise. If the head cant move downwards it sounds like the top rail belt is needing adjustment (y axis?). It took me a bit of time and trial and error to get right.
__________________ rabbit / ls3040 |
hi i read your problem about a Laser Cutter. we also manufacturs all kind of machinery and the manufacturing we do is best in quality and all kind of tools available here everything related as Laser Cutter Steel Rolling Mill Plants & Machinery if you want to know more about it and any thing related to that then visit. thanks |
#10
| I am glad its working. you could try some oil on the runner as well? I dont think there are many laser technicians in the UK apart from the one or two companies who sell them, you would be paying a lot in call out charges.
| Hello new here. Want to buy a laser cutter | smartresins | Want To Buy...Need help! | 13 | 09-06-2011 02:04 AM |
| CNC Laser cutter versus CNC Plasma cutter? | squale | Laser Engraving & Cutting Machines | 10 | 04-26-2009 04:59 PM |
| help with new laser cutter | shellglen69 | Laser Engraving & Cutting Machines | 8 | 09-18-2008 07:28 AM |
| Need Help!- ctr laser cutter | teddybear | Want To Buy...Need help! | 0 | 08-30-2008 11:33 AM |
| Why buy a Laser cutter when you can modify a laser engraver. | spacifique1 | Laser Engraving & Cutting Machines | 7 | 08-13-2007 02:39 PM |
