Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-02-2010, 07:43 AM
chameleoncav is on a distinguished road
How to fix table on HX 3040
Someone have overadjusted the table in our HX3040 and wound it too far down. It has now jammed and seems to have disconnected the adjuster knob from the rest of the legs. I assume there is some sort of belt drive connecting the legs that has fallen off. There dosen't seem to be any obvious way to get into the table.
Any ideas how to dismantle the table so I can get into the adjuster mechanism?
Old 01-02-2010, 05:52 PM
Mark Salt is on a distinguished road
This happened to me too, I managed to get it working again by twisting one of the other legs by hand.
Old 01-10-2010, 10:40 AM
Magritte is on a distinguished road
I had a problem where because they did not clean out the machine after they drilled the holes on it and some swarf got stuck in threads of the table machanism. So I took the screws out the the top of the table and gave the whole mechanism a good clean.
It says in the manual not to dismantle the table because it needs a special tool to assemble it. I now have some nuts which I cant put back on the runners, however the runners seem to be threaded so it doesnt seem to make any difference.
Anyone still running a Makino EC-3040???? Helix60 CNC Plasma and Waterjet Machines 4 07-07-2010 07:24 AM
3040 control board wanted geekinesis Laser Engraving & Cutting Machines 1 12-23-2009 01:57 AM
Does anyone else have the usb version of the 3040? (either rabbit or ls or hx?) geekinesis Laser Engraving & Cutting Machines 0 10-14-2009 05:40 PM
New HX 3040 owner chameleoncav Laser Engraving & Cutting Machines 3 10-01-2009 08:45 AM
using gas to stop fire on 3040 laser? StarLoc Laser Engraving & Cutting Machines 0 06-25-2008 01:20 PM
