Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-28-2009, 05:15 PM
vsystems is on a distinguished road
Assistance needed with chinese laser
Hi, we got a chinese laser unit 80W at the end of November. Not really sure of the brand since they're barely marked. We had good luck with it up until today when it was powered on, the gantry has a movement problem.
This unit has two speeds for each directly, the "fast" movement and the normal step movement. When you aren't engraving something, and the movement buttons are held down it kicks into fast mode. The unit works fine in all directions in fast mode, but when you press the forward or backward movement button it just vibrates loudly and barely moves or moves with massive resistance. If I power the machine off, I can move the gantry by hand smoothly in all directions. I've cleaned and lubed the linear rails, and checked all the belts and pulleys and everything seems to be solid and tight. I've got no idea what the problem could be.
Any help would be appreciated.
Thank you!
Ron.
Old 12-28-2009, 05:29 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Ron,
Does the machine engrave correctly in all directions?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 12-28-2009, 06:03 PM
We did a test engrave and no, any fine Y axis movements (front to back, I believe that's Y) do not perform correctly, it looks like chicken scratch. It's like the Y axis motor has no torque at all when doing fine step movements, but plenty of torque when it kicks into fast mode. I just finished retensioning all the belts and that didn't solve anything. It's extremely difficult to retension those buggers too, it seems the belt is clamped onto itself and inside each area where the belt is folded is a scrap piece of copper wire. I'm guessing to add thickness to the belt clamp.
Basically, pressing the movement buttons, you can see the motor in the back twitter back and forth as if it was having a difficult time moving the gantry, but if I add a little push along with the button press it moves ok. eventually, if I hold the button down it thinks i'm asking for a long distance movement instead of a step, kicks into fast mode and moves perfectly.
I don't know if it would help to post a video of it in action, I could if it would be of assistance in diagnosing this. I also checked the machine for levelness, it's level, and I can't understand how just last week it was operating fine and today it's all screwed up.
Old 12-28-2009, 06:40 PM
jalessi's Avatar
Question
Ron,
Are you sure nothing is binding?
From what you are describing it sounds like it is missing steps.
A video may help diagnose the problem.
Jeff...
Old 12-28-2009, 07:01 PM
Jeff,
I've checked every possible angle and point of contact, used a really slick dry film lubricant on the Y axis, and can move it with a small amount of effort when the machine is off, the exact same amount of effort it requires to move the laser head left and right, so I can't fathom what it could be binding on. I've never had any CNC machines other than this one, so I'm stumped, and the chinese manufacturers are no help since they've just told me to clean/oil it and "it be good again"
I've dealt with linear rails on a printer before, so I know they're good and solid, but since the machine is hardly used, I can't figure out what the heck happened between now and last week when it worked perfectly. Last thing I cut in it was styrofoam, and although I've never cut styrofoam, I'm sure it didn't destroy the gantry. Another strange thing I noticed today is the Z axis for the table is moving unbelievably smoothly, before it used to rattle and make a hell of a noise, now it's smooth as butter. Honestly I wish that was rattling again if it would fix the main part.
I've uploaded a video to youtube here.
The sound appears to be out of sync... I hate youtube.
The HQ mode is much clearer in quality too.
and as far as I can see by watching it, it's not missing any steps unless the motor, internally, has something broken inside it like a broken tooth that I can't see...
Old 12-28-2009, 07:26 PM
jalessi's Avatar
Question
Ron,
Is Mach3 controlling the laser?
Do you have a instant messenger?
My yahoo id is: jeffalessi
Jeff...
Old 12-28-2009, 07:32 PM
Jeff,
I'm not in the know enough to know mach3, I've heard of it, but don't know what it is. And in any case... I found the problem. I started pulling screws out and low and behold, the stepper motor without ANY load and without any belt on it behaves the exact same way as the gantry was moving. So.. the million dollar question is, is it possible to replace this without the help of the manufacturer?
I'l post more info on it soon as I pull out the remaining screws.
Old 12-28-2009, 07:41 PM
Rob West is on a distinguished road
Hi
On my Chinese laser the steppers are the same on both axis.
Can you swap the waring or the steeper controllers to see if the problem moves to the other axis? (only do this if you are electrically minded).
It sounds to me as if the FET’s or similar are not firing correctly on that motor controller.
Cheers Rob
Old 12-28-2009, 07:46 PM
I'm electricallyt minded, not so much for electronics though, so I pulled the motor out completely had to cut wires in order to do so because they fed the wire through a small metal hole, under the laser tube and then put it through another hold and attached a socket style end to it that won't fit through either hole.. honestly why put a socket on it if it can't be pulled straight out. I can put that back together if necessary, but anyway, now I think the issue may be electronic since the stepper seems to move smoothly in my hand the only markings are JigoCheng, DC 5.2v... then a big hole where some of the label was torn away. Type 57BYGH350B-YH.
I have a bench power supply I'm going to attempt to put 5.2v into it and see if it jiggles or anything.
Does the motor itself have a reversing gear (in case of a jam) or is that the electronics that reverse the motor?
Correction the label says "DC 5.2" the A or V is cut off, so I don't know if it's 12v and 5.2A or 5.2V?
Old 12-28-2009, 08:05 PM
jalessi's Avatar
Exclamation
Ron,
Most likely the stepper motor is good.
The stepper driver is most likely the culprit.
Do not try and run the motor with a power supply.
I suggest you stop experimenting unless you want to cause more damage.
Guessing is going to get you in trouble.
Jeff...
  #11   Ban this user!
Old 12-28-2009, 08:09 PM
jalessi's Avatar
Post
Ron,
Follow the wires from the stepper motor to where they terminate and take a picture of the control "stepper drive"
That way we can identify it and suggest a vendor to order a replacement.
Jeff...
  #12   Ban this user!
Okay, closing in on the problem here.
I'm gonna put the motor back in.
I switched sockets for the stepper motors, and then the X axis started acting the same way, switched them back and X is good again, Y is bad. So yes, the driver is bad. Does this happen often?
So I'm gonna send a few pictures here, If someone would be so kind as to point out what I'll need to look into replacing to get this working again, since I can't tell what's plugged into what, I'm assuming the twin boxes are for the steppers? The wiring is so precise and neat in this unit it's actually making it difficult to troubleshoot.
So if anyone could assist me, again, I'm very very grateful.
Add US made laser module to Chinese laser? glintid Laser Engraving & Cutting Machines 13 05-02-2012 02:43 AM
Newbie- should we buy this chinese laser ?? albo Laser Engraving & Cutting Machines 41 06-27-2011 01:21 AM
Where to buy a Chinese 80W Laser PaioX Laser Engraving & Cutting Machines 25 09-17-2010 02:57 AM
Mitsubishi DWC 110G Wire EDM Wiring Installation Assistance Needed worldsworstfish EDM Machines 2 10-19-2009 10:03 PM
Chinese Laser FMA1 Laser Engraving & Cutting Machines 3 03-19-2008 06:38 AM
