Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-22-2009, 02:26 PM
2A-TB@ThePatch is on a distinguished road
Filling....
Trying to understand how "filling" works.
After I have engraved text into (for example: black acylic) the lettering is still black..
How do i "fill" that text and make it white or green or whatever color? Does the engraver fill the color if you want it to? Is there a "filling" process after the engraving is finished?
Any help appreciated. Thanks
Old 12-22-2009, 03:18 PM
zax15uk is on a distinguished road
There are various techniques.
You can cut a 'fill' inlay with contrasting Acrylic (or from another material) and insert it in with some suitable adhesive or use an Acrylic paint (just the stuff you'll find at any hobby store). The paint is easier for detail and self levels, the process is very quick and easy.
Depending on the application you can purchase Acrylic ply which has 2 or more colors in a sandwich, you laser through the first layer to reveal the layer beneath and so on. It is the easiest (as you don't need to do anything) but costs more than paint fill and is only available in certain colors/thicknesses etc.
There are other methods too but the above are probably the most common.
Zax.
Old 12-22-2009, 03:40 PM
SkipW is on a distinguished road
More good info for color filling acrylic here.
Old 12-22-2009, 04:34 PM
Just so it isn't confusing, the method linked by Skip is 'reverse fill' for transparent Acrylic. It has the benefit that the front surface is flat/smooth and also provides a more glossy appearance. You can also engrave on thicker material and produce a very 3D look.
Zax.
Filling the machine velocity tab kolokithas DeskCNC Controller Board 13 09-25-2010 04:21 PM
Spalted maple finishing/filling CyborgCNC WoodWorking 8 09-06-2007 10:29 AM
Filling holes on magnesium wheels? PeeBee Casting Metals 1 01-21-2007 04:53 PM
filling aluminum extrusion with plastic gbell212 Moldmaking 7 09-01-2006 05:31 AM
Filling machine time zachf CNC Machining Centers 3 04-05-2006 07:50 PM
