| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hello, I've been told that there should be a ballast resistor between the power supply and the anode of the tube. This is a common requirement for gas discharge tubes, such as HeNe lasers. The resistor is used because the laser tube has negative resistance, and you need a positive resistance to cancel that out. However, everything I've seen regarding the Chinese power supplies & sealed CO2 lasers indicates that no ballast resistor is necessary. The instructions that came with my power supply say to just connect the HV lead directly to the anode of the tube. Has anyone seen one of these sealed CO2 tubes with a ballast resistor in the anode circuit? Or, does anyone know why the resistor is not needed? Thanks, Neil |
| G203V Power supply and resistor | Mooser | Gecko Drives | 1 | 04-29-2009 10:23 PM |
| Ballast Resistor Needed | jimmy2020 | Laser Engraving & Cutting Machines | 4 | 10-19-2007 11:42 AM |
| Ballast Resistor & 24v Power supply | arman | Hobbycnc (Products) | 0 | 04-10-2007 12:23 AM |
| Power Supply Bleed Resistor | pcstru | General Electronics Discussion | 3 | 10-17-2006 06:50 AM |
| Help determining correct power resistor | mvaughn | General Electronics Discussion | 2 | 04-16-2004 03:54 PM |
