Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-16-2009, 10:10 AM
rkovvur is on a distinguished road
home built laser engraver : what type of linear drive ?
For the laser engraver i am planning to build, I am now stuck on the issue of the type of linear drive for the X and Y axis.
I'd like to know what others are using.
I initially planned on using lead screw type (ACME with delrin nut). Then thought of changing to ballscrew. Now i see that commercial lasers use the belt type(this gives no backlash, but the motor needs to be handle the inertia of the gantry).
If you guys are successfully using a drive mechanism, plase share it
Old 12-16-2009, 11:59 AM
zax15uk is on a distinguished road
rkovvur,
For a laser application the gantry and head (optics housing) is low mass, and higher speed so a belt drive is typically used.
A CNC machine has a heavier gantry with more mass for the spindle etc so a ball screw would be optimum and a lead screw acceptable.
I would recommend the belt drive if it is a pure laser system.
Zax.
Old 12-16-2009, 01:28 PM
Thanks!
My worry about the belt drive is its resolution. And the belt tension and i believe that the stepper would need to have higher torque.
In a screw drive, i guess a lower torque motor can be used, right?
Old 12-16-2009, 03:33 PM
Resolution should not be a problem with the correct pitch belt and pulley. If you are concerned about belt tension you could add a spring loaded automatic tensioner.
You won't need much torque, so it shouldn't be a problem. I would always use a belt drive for laser applications.
Zax.
Old 12-19-2009, 01:59 AM
wktina is on a distinguished road
laser machine
belt and stepper should be your ideal and economical choice
Old 12-22-2009, 06:17 PM
pixpop is on a distinguished road
What about belt drive with a servo instead of a stepper? Any reason not to do that?
Old 12-23-2009, 07:47 AM
Servo and belt would be optimal, but higher cost compared to a small stepper.
Zax.
Old 12-23-2009, 08:04 PM
if you want to use a servo instead of stepper,then belt is not a wise choice,precision can't be satisfied.
so you should choose servo motor with ball screw
stepper with belt is optimal partner
Old 12-23-2009, 08:53 PM
I think you're probably right, but I'm not sure I understand. Can you not improve precision by increasing encoder resolution?
Old 12-23-2009, 09:50 PM
increase encoder resolution will not change much.this is rigid problem,but belt is too flexible.if you want to know details,pls write me email
tina@wklaser.com
  #11   Ban this user!
Old 12-24-2009, 08:41 AM
Servo and belt drive is an ideal solution for high speed applications. You can achieve much quicker acceleration and faster rapids compared to a stepper.
It may not provide any better resolution when coupled with a belt (although this isn't necessarily true) but it will be quieter and smoother.
With the low loadings of a laser system the belt drive is the way to go, and if cost isn't the major factor I would use servos.
Zax.
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
Can A cnc hurca type be built for home shop? ruawake HURCO 4 06-11-2009 07:44 AM
Acme Thread, Ball Screw Or Belt Drive for Laser Cutter/Engraver? pyrofx Laser Engraving & Cutting Machines 5 04-08-2009 03:59 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
Home Built Router/Drag Diamond Engraver DaSigntist DIY-CNC Router Table Machines 49 01-24-2005 01:02 AM
