| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Materials: Acrylics/Wood possibly some aluminum down the road. Engraving/filling. I'm looking to do work similar to the picture below (small graphics with some lettering) Maybe 5 or 6 projects a day, and just at home..... I have been looking at the Epilog Mini 18.. Can anyone help me with this info? What I should be looking for? What I need besides the actual Laseer maching (i.e software, etc) The help is greatly appreciated. Last edited by 2A-TB@ThePatch; 12-14-2009 at 03:24 PM. |
| Basically any CO2 system with a rotary adapter would be fine for engraving acrylic (it's probably the easiest of materials), wood shouldn't be any problem either. The aluminum, since it's a lower priority could be done with an additive process if needed. So to answer your original question, yes the Epilog Mini 18 with optional rotary attachment would work fine. The engraving would be of sufficient depth to fill with color, rub n buff or paint etc. Zax. |
| The Epilog is a good choice for a US supported system, and it has a modern air cooled laser tube. ULS Versa series is worth checking out but may be over your budget. I wouldn't recommend the Chinese systems unless cost is the primary factor and you are willing to invest some time learning to be a tech. Zax. |
| The picture you posted I cannt see it,can you post it again? |
| Kevin, I am normally the first to recommend a CNC router (I do 20X more work with the router than the laser) but in this application a laser looks to be the right tool. 90%+ of the item is Acrylic or wood and if he needs to mark the aluminum ring Cermark or similar would do a nice job. Zax. |
| Zax Laser machine can do well on engraving arylic and wood,especially on engraving and cutting machine, but it make no sign on the metal such as aluminum.If he buy the laser machine,when want to engrave the aluminum,I dont think this is good idea to find other tool to finish the work just because of the possibility of the work is little.If one tool can acehive all,why go to find two other differnet tools to do that?I dont think this is a good idea. |
#10
| Kevin, Cermark is not another machine, it is a brand name for the additive laser marking process (also sold as Thermark). http://www.ferro.com/Our+Products/Co...rkets/CerMark/ This would require spraying the aluminum (or paste/tape) which the laser then bonds to the metal. It is very effective and produces a nice black mark. It isn't cheap, but for a small area is reasonable. It was even discussed recently on here how to make the fluid using cheap ingredients although I haven't tested how well that works. Just a comment on the Thermark though. I recommend the paste which can be diluted several times more than the manufacturer suggests and then sprayed VERY thin with an airbrush. It is extremely abrasion resistant when done correctly. Zax. |
#11
| That really looks cool... haven't got an idea of engraving these type of materials... thanks for your post 2A-TB@ThePatch.. Marking Systems |
#12
Thanks your sharing Cermark with me.But I think he need a machine to engrave the aluminum not spray on it. Kevin |
| New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! | oliver9866 | Engraving Machines | 2 | 12-15-2010 02:44 PM |
| laser engraver | Stone guy | Canadian Club House | 0 | 04-24-2008 08:15 AM |
| Paneling question start...finish | abelloise | ArtCam Pro | 3 | 12-03-2007 11:09 AM |
| Why buy a Laser cutter when you can modify a laser engraver. | spacifique1 | Laser Engraving & Cutting Machines | 7 | 08-13-2007 02:39 PM |
| PCB routing from start to finish | Swede | General Electronics Discussion | 7 | 01-29-2004 06:20 PM |
