| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Please anybody can inform me about the availibility of automated motion laser PCB engraving and drilling machines ? Or any general aimed laser engraver which can be used for PCB also ? Thank you very much for your answer. |
| Hello charles, it's not possible to etch the copper away with a CO2 laser. There are some lasers capable of doing the etching but those machines are quite expensive and have a different type of laser. I researched this myself and decided not to buy a laser capable of this because of the high price. Better just get the resistance layer away and do the etching chemically. |
Laser-Based System Speeds PCB Prototypes This high-speed, programmable system is ideal for laser structuring, milling, and drilling of soft and ceramic substrate materials for creation of RF/microwave PCBs.... http://www.mwrf.com/Articles/Index.c...ArticleID=9571 |
| LPKF quite expensive and seriously overpriced laser equipment. I have good experience with routing LPKF equipment and it is good, but cost of tooling slightly more then I accept. So, I looking for possibility to make a home brewed laser engraver and laser drilling unit. I think it is possible. If any one has experience, please response. Thanks. |
| Using a CNC router and micro end mill is cheaper, but YAG laser would do what you want (etching copper and 'drilling' PCB). Yb:YAG is the cheaper option, but expect to spend around $15k for a used diode. Zax. |
| Hi Guys, For simple and I stress simple pcb's I have found isolation routing to be an excellent way of making. It's clean, easy and relatively quick. http://www.cooperman.talktalk.net/circuit5.wmv ![]() For slightly more complicated pcb's I have had reasonable success with spraying the copper with car paint, CO2 lasering away what is not wanted, etching then removing the paint. ![]() Only problem with this method is that you don't have a drill file so the holes have to be drilled manually (or create a drill file I suppose). This method is quick and perhaps best suited to surface mount stuff (no holes to drill). ![]() Don't know if this helps but it may be food for thought. Tweakie.
__________________ CNC is only limited by our imagination. |
| Hi Charlesdel, I am happy to see your information on cnczone . I am Mandy from JCUT. Dear, can you considerate use cnc machine for PCB ? If yes, i hope you can check our JCUT professional PCB machine on ebay ,the link is 3030 pcb router pcb drill mini routing drilling machine - eBay (item 130449195096 end time Jan-26-11 22:46:46 PST) Hope to get your reply. Thank you Mandy |
| New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! | oliver9866 | Engraving Machines | 2 | 12-15-2010 02:44 PM |
| Need Help!- Laser Engraver | jweinhold | Want To Buy...Need help! | 1 | 11-04-2009 02:07 PM |
| Need Help!- Laser Engraver | jvpatel | Laser Engraving & Cutting Machines | 1 | 03-14-2009 03:25 PM |
| Why buy a Laser cutter when you can modify a laser engraver. | spacifique1 | Laser Engraving & Cutting Machines | 7 | 08-13-2007 02:39 PM |
| Laser Engraver | arisking | Laser Engraving & Cutting Machines | 5 | 06-23-2007 04:39 AM |
