Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-18-2009, 12:37 PM
eclipsah is on a distinguished road
Angry Ferranti MF400 Laser source
Hi. I'm new to this forum. I own a Lasercomb C112 CNC with a Ferranti MF-400 CO2 Laser source. It looks like this:
http://www.lasercomb.com/fileadmin/f...s/plsmf600.jpg
After thousands of work hours and improper servicing, from the rated 400W power it now has only about 40w. I've cleaned all the mirrors, tubes, high voltage connectors, gas valves... etc, new output window (plasma -> laser ray), aligned the tubes... and still no power. Can anybody help me with this machine?
Old 07-17-2010, 05:04 AM
patrick2805 is on a distinguished road
Hello,
i have 2 ferrantie mf 400 machines, 1 MF 600 and MF1000 machine.
I can be that the gas mix is not ok... it also can be that the oil filter on the vacuum pump is full, en that you have got a littlebit oil in the oven....
The problem that you have then is after purge the power is dropping but machine is running stable... what is is the color off the sourche? bleu?..
is the machine not running stable and do you get any error?
also when you need spare parts.... i have allot available for these machines.. even the controller off the lasercomb i have on stock...
Best regards,
Patrick
p.jongeneelen@hotmail.com
Old 07-17-2010, 06:54 AM
Thanks for the reply
Since I posted this I've learned a lot about CO2 lasers. In the meanwhile I've checked everything that you said. It seams that the tubes were replaced with "homemade" ones, and do not have equal length -- and the internal tubes are not perfectly round, causing the plasma to reflect into the electrodes. Do you know where I could buy cheap original/quality cloned tubes, since you have so many machines?
Best regards
Old 07-17-2010, 08:47 AM
Best regards
Hello,
When the lenght is not ok, this can also mean that the allingnment als can be wrong!
So when you have new discharge tubes it can be possilble that you have to do this again... I have an full set for the MF400 available, these are original ones.
But please also check the output lens, iff this placed in with right direction!!
Then you loose also al lot off power.
So how many discharge tubes do you need?
i have an complete 600 watt sourche available for an good price..
This sourche is exactly the same like the one you have... (the only differnce are the discarge tubes and metal part that are on the catots) so you can used if for spare parts or place the complete sourche on...
Best Regards,
Patrick
Old 08-11-2010, 04:42 PM
lasetek is on a distinguished road
Ferranti laser
We are the original manufacturer of your laser.
email me at lasetekservices@btinternet.com and I will give you full details.
We have all the original parts and technicians to work on your laser.
Tags
cnc, ferranti, lasercomb, mf400
Need references about DC exited 100 Watt laser source from GSI Spectron, UK. Litografa Laser Engraving & Cutting Machines 0 09-21-2009 07:04 AM
US Source For Laser Tubes laserous Laser Engraving & Cutting Machines 2 08-31-2009 11:50 AM
Need A Quote- Need Laser Cutting Source Southeast Michigan SteveS Employment Opportunity 0 05-21-2009 10:30 PM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
Problem- Laser source don't work mhbacca Laser Engraving & Cutting Machines 8 07-14-2008 08:42 AM
