Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-03-2009, 07:20 AM
TheWorkshopGuy is on a distinguished road
Laser Cut V53 software???
I have Laser Cut V51.. does anyone know if version 5.3 will work with my current dongle and if so where can I download the new software?
DB
Old 11-03-2009, 05:32 PM
SHADOW042 is on a distinguished road
Smile LASERCUT 5.1
No
They are not interchangable
You cant even use one from lasercut 5.1 dongle from one supplier to a different machine with lasercut 5.1 software supplied from a different manufacturer
They seem to be supplied with the supplier in mind only
Ie.. if u got 5.1 software from redsail and dongle from say some other supplier
It wont work as I have already tried this with software from redsail and dongle from red dot international (both lasercut 5.1 but redsail has a memory onthe machine and uploads mol file but reddot requires computer to run the software ) and they are incompatable This may varie depending on manufacturer but they def wont work with dif versions
Shadow
Old 11-21-2009, 06:43 PM
digital_life is on a distinguished road
DB
i have a copy of the 5.3 version, i could email it to you if you want.
i bought the 6515 leetro board, and supposed to come with lasercut 5.1 version. didnt. but i got the dongle for that version (supposed to) and still work on the 5.3 version too...
you can try youself..
you may have to make a firmware update at your own risk..anyway its easy to do.
Old 11-23-2010, 08:31 PM
Roberto TT is on a distinguished road
Lasercut V5.3
Hi: Does anybody has a Lasercut V5.3 users manual in English? The one I have is a translation from a Chinese manual and is not too good to say the least.
Thank you for your help.
Roberto
CO2 laser software cosmo2 Laser Engraving & Cutting Machines 3 10-21-2009 01:02 PM
5-axis laser software smessi General CNC (Mill and Lathe) Control Software (NC) 0 07-14-2009 04:56 PM
Problem- Laser fires on "Laser Test", but not from software SimonArthur Laser Engraving & Cutting Machines 6 06-18-2008 02:32 PM
Asking about a Laser CNC Software waleed alhadidi CNC Plasma and Waterjet Machines 4 06-17-2008 11:20 AM
Software for laser cutting PeterCharles Laser Engraving & Cutting Machines 0 11-24-2007 07:47 AM
