Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-02-2009, 08:29 AM
KPBadger is on a distinguished road
Air Assist for 60watt laser - capacity?
Hello All
i am going to replace my noisy and over-powered ( the noise is the real problem ) air compressor with an aquarium pump such as this:-
http://cgi.ebay.co.uk/150-LITRE-A-MI...item483691aa00
any suggestions for what capacity i should go for ?
- similar design unit seems to be available in 45, 90, 120, 250, 45 Litres/minute.
alternatively the power rating of the motor would allow me to choose correct specification.
What do other forum members use for air assist?
(*NB i note there a few other posts on this subject but cant seem to find any numerical answer to the question )
thanks
Kpbadger.....
Old 11-03-2009, 02:22 AM
Litografa's Avatar
Litografa is on a distinguished road
I think minimum is 45 liters per minute. Better have some extra power, so 90 liters will be good choice.
Old 11-03-2009, 03:16 AM
Air assist
thanks Litografa - sounds good.
i will probably put together some kind of reservoir and regulator with it, for some control of airflow.
best regards
KPBadger.
Old 11-03-2009, 03:24 AM
Litografa's Avatar
Regulator is must! Sometimes you need high air flow, sometimes very small. With our current compressors we have not enough space for regulation
Tags
air assist pump
Fadal Assist and XP egw Fadal 15 11-15-2010 03:16 PM
What is air assist? greif Laser Engraving & Cutting Machines 5 04-08-2009 03:13 AM
Fadal Assist robsbfilters Fadal 5 03-23-2009 03:23 PM
Fadal Assist Michael82 Fadal 1 03-20-2009 04:10 PM
plug assist material spock Vacuum forming, Thermoforming Etc 1 09-15-2008 08:39 AM
