Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-27-2009, 04:16 AM
craig3000 is on a distinguished road
Hi and help needed cutting white acrylic!
Hi guys, noobie on here i wondered if anyone could help me. Im trying to cut 3mm white acrylic on a 400w multicam laser, my problem is im getting burn marks on internal rads. I would normally clean these off but i have a big order to cut! Any help or tips would be brilliant!
Craig
Old 10-27-2009, 06:06 AM
Litografa's Avatar
Litografa is on a distinguished road
Hello,
Please send pictures of problem. Do you use cutting table? If yes - how it looks? Do you have air assist with air compressor or you can add CO2 to burn area?
Old 02-28-2010, 07:28 PM
Bryden is on a distinguished road
A low pressure oxy assist gas should help clear it up no problem, hope thats an option for you. Clear perspex comes out clear on the cut edge with the right setting and oxy assist
Just IN- Acrylic cutting machining john petre Product Announcements & Manufacturer News 0 09-22-2009 11:39 AM
Problem- Cutting black acrylic stephaniehamer Glass, Plastic and Stone 0 08-02-2009 11:52 AM
Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine stephaniehamer Laser Engraving & Cutting Machines 5 06-29-2009 03:37 PM
Cutting Acrylic Gujustud Glass, Plastic and Stone 20 01-27-2009 07:05 PM
Cutting Acrylic SatanKlawz WoodWorking 23 07-23-2006 01:42 AM
