Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-25-2009, 01:28 PM
Micz is on a distinguished road
LaserCut 5.3 and CorelDraw 12
I have problem with lasercut 5.3 plugin for CorelDraw 12. I want to engrave text and then cut it. I make yellow words and black rectangle around them. I set engrave for yellow and black for cutting.
When i start my machine it engraves letters but then it cuts them (each letter). I tried everything, I transformed text to curves, removed stroke, and nothing it still cuts every letter , when I tell him to cut only rectangles around words.
Can anybody tell me what should I do?? Thx for help in advance.
Old 10-25-2009, 02:39 PM
Litografa's Avatar
Litografa is on a distinguished road
Hello,
May be you can attach this file first and we will check it? If everything will be fine with CDR file, at least we will be sure that reason of problem is in LaserCut.
Old 10-25-2009, 02:55 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Did you try seperate layers, for each operation?
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 10-25-2009, 02:59 PM
zax15uk is on a distinguished road
Check that you don't have duplicate text. Select one of the letters and delete it, if it does delete just undo. I have seen this happen when you convert text to curves and the text had either a stroke, or some other effect applied. It can also happen with certain fonts.
Zax.
Old 10-25-2009, 03:05 PM
Here is my file. I hope it will help in finding solution.
@Switcher
Yes I separated text and rectangles. They are in two different layers.
@zax15uk
I checked that too everything was fine.
Old 10-28-2009, 02:38 AM
cicigweike is on a distinguished road
re:LaserCut 5.3 and CorelDraw 12
You can analog output before working.
I had attached the "analog output " button's photo.
it is on the front of laser cut 5.3 software.
cici
Old 10-28-2009, 03:09 AM
I am laser engraving machine manufacture in China.
I opened your design at laser cut 5.3 software, it looks fine.
no problem.
I had attached a new document, a little adjust from your design,
please test at your software and tell me the result.
Best Regards,
Cici
Old 10-28-2009, 07:03 AM
bibi's Avatar
bibi is on a distinguished road
hello,
i have lasercut 4, is it possible to upgrade on lasercut 5.3;
Old 10-28-2009, 09:53 AM
laser cut 4 software is too low, so can not upgrade to laser cut 5.3.
If your machine working well, we do not suggest upgrade.
because laser cut 5.3 have it is deficiency too.
Old 10-28-2009, 03:23 PM
cicigweike yes it work, but I needed to make it work from corel draw, but I found solution. I export to autocad format in corel and than import in lasercut. It works 100% .
  #11   Ban this user!
Old 10-28-2009, 09:12 PM
Hi Micz,
I had attached our software manual, please check them, you will find all your question's result from this manual.
I think your driver is MPC6535, but it operation as the same as MPC6515.
MPC6535 drivers-set up-install path-choose "CorelDraw" from option (AutoCAD, Coreldraw, Laser cut).
So that you can use Coreldraw output directlly.
Best Regards,
Cici
  #12   Ban this user!
Old 02-14-2010, 12:05 PM
ahmadobayat's Avatar
ahmadobayat is on a distinguished road
Question i need help
hi
i need the lasercut 5.3 software to instal it
because i lost my cd and my golden sign laser machine is not working ...
can any one here give me help ?
my email is ahmadobayat@live.com
CorelDraw - CorelTrace CJL5585 General CAM Discussion 4 02-06-2011 07:05 PM
Lasercut 5.0 & coreldraw problems durtydogg Laser Engraving & Cutting Machines 41 05-16-2010 02:48 PM
DXFTool V2 for CorelDRAW is released jemmyell Product Announcements & Manufacturer News 0 03-08-2009 08:43 PM
Is anyone using CorelDraw for artwork?? Jeremy_Wittlock DynaTorch 2 11-13-2008 09:46 PM
Tracing Artwork in CorelDRAW jemmyell General Metalwork Discussion 0 03-10-2008 10:50 AM
