Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-25-2009, 04:00 AM
jimreeves is on a distinguished road
80w laser cutter, spark, flames
We have just got a second hand rabbit 80w laser engraver and first problem was sparks arcing from tube end to machine frame. solved that with silicon sealant.
It ran well for half an hour then sparks came from the tube power supply, see photo. lots of burnt plastic, mostly the fan next to the HT outlet.
Anyone know what's going on? should we buy a new power supply? have we got a deeper problem?
Old 10-25-2009, 10:05 AM
zax15uk is on a distinguished road
Jim,
It appears the HV transformer connections have been arcing to the case and possibly resulted in the fan failing. These could both be related to excess input voltage, set for 110v and you have it hooked to 220v?
Either way it's a mess now. Depending on how long it ran with these problems it may be repairable, in fact it could just require a new fan, some wiring and re-insulating the HV.
Zax.
Old 10-26-2009, 09:22 AM
We checked if there is a swich to select 110 or 220 v for mains supply; no.
It was ok when the last owner showed it working, and it is a UK spec machine.
Some folks on this forum have had cracked tubes lead to this arcing problem, but i can't see any damage to our tube. we hope to be getting a fresh psu from importer as it's really still new.
jim
Old 10-26-2009, 10:34 AM
Has anyone got coreldraw 11 laser output controls to work?
Lasercut 5 is a an extra stage of faff between drawing and cut parts!
Tags
arcing, sparks
DWG OF FLAMES tlo1957 General CAD Discussion 2 10-12-2009 11:02 AM
Problem- Laser tube discharges in a spark buc Laser Engraving & Cutting Machines 7 04-29-2009 06:28 AM
CNC Laser cutter versus CNC Plasma cutter? squale Laser Engraving & Cutting Machines 10 04-26-2009 04:59 PM
Problem- Shop could have gone up in flames SpeedsCustom Benchtop Machines 21 05-02-2008 12:52 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
