Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-23-2009, 09:34 AM
kling8 is on a distinguished road
Looking into buying a laser
Hello All,
I have started to research different lasers. I'm looking to learn more about them, I have ran a few over the years, but im interested to know what brands have worked for you. Good contacts bad contacts. Power watts, thinking that I want at least 100 watts.
Looking to engrave wood, metal, but want enough power to cut through 1/2" of wood, and through sheet metal.
Any help would be great...
Thanks all
kling8
Old 10-23-2009, 11:16 AM
zax15uk is on a distinguished road
You may do better with a CNC router for those applications, or perhaps 2 machines.
Engraving wood, and even cutting 1/2" is reasonable for a 100W CO2 laser.
Engraving on metal would be possible with an additive process but is expensive, so for both engraving and cutting I would suggest Nd:YAG.
You need to define the equipment before I can suggest vendors.
Zax.
Old 10-23-2009, 12:22 PM
paulwilson05 is on a distinguished road
Nd:YAG....I'm using one right now cutting features into Ti surface.
Old 10-26-2009, 04:47 PM
benji2505 is on a distinguished road
Yag
Does the YAG Laser go into wood?
Old 10-26-2009, 06:46 PM
The wavelength of YAG is not suitable for cutting wood, just like CO2 is not suitable for engraving metals (directly).
Which is why I suggested a CNC machine to do both, or even better 2 machines.
Zax.
Old 10-27-2009, 08:30 AM
Thanks guys, I was thinking it may require 2 machines but figured I would see if 1 could do it. I got some info. from a few companies, looking into a few more.
Old 10-28-2009, 12:37 AM
cicigweike is on a distinguished road
Hi King,
what kind of wood do you want cutting? wood have different kinds, some hard, some soft.this decide laser cutting machine's cutting speed and cutting deep.
About metal sheet, only a little of laser engraving cutting machine can cut metal and can not cut very deep.
plasma machine and waterjet machine specially at cutting metal.
About CNC Router, soft metal is ok, but if the metal very hard, for example stainless steel, the cutter usually be damaged.
So, you should think over the hard of the material and your cutting deep.
Best Regards,
Cici
Old 10-29-2009, 11:40 AM
I'm thinking the wood I will be using various, I have a friend who has a saw mill, pine, maple, bass wood, oak, cedar, ash, focusing mostly on wood, and probably softer woods. The question on metal was, I was thinking if worked I could make templates for other projects was the metal idea
Old 10-29-2009, 12:15 PM
Slightly off topic, but I disagree with Cici's comment regarding CNC routers and 'hard' metals. Sure EDM would be preferable for some jobs but most small machine shops use CNC (with high speed spindles, coolant etc) for stainless steel. I work with stainless all day long, using diamond or carbide end mills and with coolant and the correct feeds/speeds they can last a long time and are a fraction of the cost compared to an EDM.
Abrasive waterjet, plasma and high power laser are limited to sheet materials and straight cuts.
Now back to the question from kling8, you could add a laser diode to a CNC router for the engraving and let the router do the rest. Cost would be lower compared to the other options and you can always add a plasma cutter to it later if desired.
Zax.
Old 11-05-2009, 01:33 AM
fly007001 is on a distinguished road
cnc router is ok~
  #11   Ban this user!
Old 11-05-2009, 04:13 PM
paopaolo is on a distinguished road
what are and were are the hidden costs?
Hello Gentleman's,
I approached the laser cutters thinking "buy the machine and cut/engrave for free for the rest o your life!". So save time and money...
Now I could invest those 4000 to 8000€ into a laser cutter (and still I have to decide if the cheapest is really the best), but the question is to know if the machine really run for free, how often do you need to replace or recharge this CO2 tube? Are there other hidden costs you ran in to?
By the way, did you ever try to use the laser to shape the standard furniture wood (relatively soft, 18mm thick)? is there any risk that the all plate of wook catch up in fire?
Thanks tho those who may answer..
  #12   Ban this user!
Old 11-05-2009, 04:46 PM
fullspeceng is on a distinguished road
My experience with cutting wood is that the laser ALWAYS leaves burn marks on the edges that you won't get with a CNC router.
I prefer this look as it looks like a black paint on the edges and has nice contrast. If you are careful you won't burn the tops but I've set fire to wood many times when not careful.
Even with my 40W laser I can cleanly cut through 1/4" hardwood in 1 pass with appropriate PWM power control. I can probably do 1/2" without too many problems with the 50W that are coming next week.
I don't think mounting the laser head on the end of the router is a good idea.
Laser mirrors are pretty cheap ($50) and you can keep the tube stationary and bounce the beam down to the surface.
That said, I wouldn't operate a non enclosed laser beam. Seems pretty dangerous to get a reflection into your eye.
Laser tubes usually last 1000-3000hours depending if you take care of it. PWM pulse mode is way better for the tube. Even the more expensive 80 or 100W tubes are only like $600 so I'd figure around 10-50cents/hr to run. Your electricity bill probably costs about the same so I say the laser tube life is a non factor..
___________________________
www.fullspectrumengineering.com
low cost CO2 laser cutters, Inkjet PCB kits, Laser 3D Scanning, Solidworks 3D Mechancial Design, Electrical Engineering Design, overseas CNC manufacturing consulting
Newbie- Advice Wanted buying a small laser cutter Jolijar Laser Engraving & Cutting Machines 4 08-17-2009 09:34 AM
Need Help!- Buying a laser from China VBLietuva Laser Engraving & Cutting Machines 4 07-20-2009 05:56 PM
My experience on buying (righ now) a Chinese laser keops777 Laser Engraving & Cutting Machines 12 05-22-2009 06:36 PM
Buying Laser Soon For Business Application - Recommendations Please SCG11762 Laser Engraving & Cutting Machines 5 07-31-2008 09:32 PM
Buying a used laser cutter? SimonArthur Laser Engraving & Cutting Machines 0 08-05-2007 03:22 PM
