| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
any one working on it? i can't find settings how perfectly to cut aliuminium on Cutting condition table, how to set the best cutting parameters on material named : A1050-1.0 or others..for aluminium. thanks a lot for your help |
| Alloy can be a real drama, especially when it starts getting thicker, try dumping as much assist air through as you can, pretty much just to "blow" the slag off right away, we're cutting some 0.45mm thick alloy shims right now and it still has to be cleaned up even with 7kg/cm(squared) of pressure. I've been told that when piercing alloy it can create a pool of molten alloy and reflect the beam back up to the lense, if you don't have the correct pierce settings, which sounds bad to me, we generally use a waterjet for alloy just for this reason, don't take my word for it tho, thats just what I've heard. |
| Need Help!- Amada 357 | Independent CNC | Fanuc | 8 | 07-18-2011 01:13 AM |
| amada laser | 55belairtim | Want To Buy...Need help! | 1 | 03-23-2009 03:19 AM |
| Amada EZ cut | TLC | Laser Engraving & Cutting Machines | 1 | 03-23-2009 03:17 AM |
| Problem- Amada Vega-344Q | DHO.nl | Controller & Computer Solutions | 0 | 10-08-2008 02:31 PM |
| amada lasmac | edgegauthier | Fanuc | 0 | 02-11-2008 11:52 AM |
