Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-14-2009, 04:16 AM
Fertito is on a distinguished road
Lightbulb Adding a Laser to cut nylon and polyester material.
Hello there!
I'm french hobbyist specialized in kite and paraglider building, I can make up to 10 wings (all discipline included) per year.
Some time ago (nearly 6 years) I started building plotter/cutter for such materials, I've got 2 proto plotter working (1 at a friend house, and 1 in a hangglider factory), and now I'm using a pizza wheel cutter to cut the materials.
here is some pictures :
I'm planing on buying a 20w CO2 laser tube to do the job, and mount it on the plotter instead of the cutting wheel.
thanks to this forum to make it possible...
Old 10-14-2009, 07:59 AM
zax15uk is on a distinguished road
Hi, I would suggest you try on a laser first, if you haven't already. Nylon cuts clean but in my experience some Polyester melts and does not like to cut very well.
It could be you just need more power for a good clean cut, 80W CO2 may work ok.
Zax.
Old 10-14-2009, 08:07 AM
Hello,
I spent some time gossiping with the manager of a paraglider factory, He told me they were using a 28W (synrad) laser at nearly half power for nylon, a little more for Dacron (polyester) and that they also cut fiberglass with it (in fact these are thread of fiberglass between 2 layer of mylar).
Maybe I'll try to buy a 25W laser or so, try it and after that I'll try to implement it on my plotter.
I forgot to say that I develop my own software for my plotters
Old 10-14-2009, 05:02 PM
I haven't tried fabric, it was Polyester (Mylar) sheet. So a woven fabric is probably much easier to cut since each fiber will seperate.
Are you using a step/direction driver and your software or have you developed a PLC design?
Zax.
Old 10-15-2009, 01:07 AM
when I started building my first plotter, I was using a simple ULN2003 to drive the stepper and was working coil by coil...
Now I'm using L297-L298 or so step/direction driver and this is easier...
Old 10-16-2009, 02:32 AM
juste received a price from Eclaser:
25w laser tube : 127$
40w psu : 172$
lens : 28$
shipment & insurance : 209$ (ouch!)
thinks I'll go for this...
Old 10-16-2009, 03:06 AM
The glass tube is fragile, so they probably expect a few aren't going to make it. Don't forget the mirrors, unless you already have them.
Keep in mind the 25W Chinese tube is not near equivalent to the 28W Synrad, you'll need at least a 35W and probably 40W to compare.
Zax.
Old 10-16-2009, 03:32 AM
I don't need mirrors, I want to put the laser head in a vertical enclosure with the lens directly in the path.
my plotter is 2 meter x 3 meter and will soon become 2x6 so I don't want to play with focusing...
I'll first do a try with a 25w laser tube, what I found is only a few watts are needed to cut such fabrics (less than 10) at a fast speed.
My plotter is not going that fast, only 10cm/s and I don't need it to go too fast.
Aeronaut has a 40w laser head that can go up to 1.2m/s... I don't need this.
And I don't want to cut steel, I just want to cut low temp melting fabrics.
Old 10-17-2009, 08:32 AM
Mounting a glass CO2 tube to your Z-axis is not a good design, I know it seems like the easy and logical setup but it isn't. The motion and vibration will result in a cracked center tube (it is basically suspended within the outer water cooling tube). Even though the machine isn't moving fast, it still changes direction quickly which is where the stress comes from. If you have steppers there is also resonance to consider.
Not to mention the water supply, HV connections etc.
Mirrors aren't that expensive and would make a much more robust system.
Zax.
Old 10-19-2009, 01:51 AM
I was thinking of doing something like Aeronaut :
with the water also on the head, the only things was to bring the HV to the laser.
My software integrate a speed correction algorythm to avoid fast direction changing, the speed decrease has the curvature of a curve is prononced.
And my head is already nearly 4kg, I let you imagine the torque needed to stop it when it run at full speed (I can go up to 40cm/sec).
But I'll reconsider my design, you are right.
I would have prefered the laser on the head for more safety, and to avoid a focusing system as the minimum lenght of the laser beam will be less than 40cm, and the maximum will be 8m...
thank yo very much Zax for your suggestions
  #11   Ban this user!
Old 10-24-2009, 03:10 AM
dar303 is on a distinguished road
maybe you should try a small diode laser? a 10W 808nm ir laser can be found cheap on ebay and optics are not especilly complicated either. no watercooling, hv or fragile glass parts and only a hekto or so of extra wheight. just remember to have some airflowto keep smoke away from the lens.
  #12   Ban this user!
Old 10-26-2009, 03:28 AM
Hello,
Yes, I understand that a laser diode could do the job, but...
I don't know which one to choose, there is so many, with so many specification (bar, ...)
I would like to do other things than fabrics cutting, I would like to try to cut eva-foam too...
Well, just have finished my own plotter, a "T" style one :
I'll use it for plotting only for now, but I would like to try laser-cutting with it soon.
Adding a laser to gantry router questions SScnc Laser Engraving & Cutting Machines 38 11-09-2011 12:06 PM
Adding a laser to a CNC - any FAQ's around? mcphill Laser Engraving & Cutting Machines 8 07-05-2009 03:19 PM
Polyester concrete base. Can this work? alexccmeister Mechanical Calculations/Engineering Design 10 07-12-2007 10:13 PM
adding laser to mill Art Ransom Laser Engraving & Cutting Machines 2 10-17-2006 10:20 PM
adding a laser to my CNC... jdbaker Laser Engraving & Cutting Machines 2 11-16-2005 07:06 PM
