Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-07-2009, 01:40 PM
geekinesis is on a distinguished road
mach3 and hx4030 machine modifications
Hi
I think this machine is similar to the rabbit version, its from hpc laser in the UK.
I was wondering if anyone had converted the machine to mach3.
So far I have the components and driver board to make all the modifications. I am just not sure which way to control the laser on/off. IE i know I can do it with mach3 software but am not sure of the physical connections to the laser control board.
It would be useful if someone could send a photo or diagram of their machine and the physical connections they made.
Old 10-07-2009, 09:56 PM
zax15uk is on a distinguished road
Can I ask why?
I can think of 2 good reasons...
1. The current driver is dead - and it's cheaper to go the step/direction method
2. The supplied software is inadequate
Mach3 is fine if you plan to do cutting only, but marginal for engraving with the plug-in. It's improving all the time though.
Do you know what input your laser PSU has, pwm or voltage? If it's voltage based you'll need a D/A convertor (something like a digispeed controller). PWM may be able to drive directly but often you'll find it requires much higher frequency than your PC can provide.
I will have a look in my notes, I may have some wiring diagrams somewhere.
Zax.
Old 10-08-2009, 04:33 AM
The software is newlydraw and is very basic. I am thinking with mach3 I can have a lot more control and I dont do any engraving. Mach3 also seems easier to set up as newlydraw has very little documentation with it.
Wiring diagrams would be very useful.
Need Help!- CNC/Laser Modifications - Need Guidance Scalesoar DIY-CNC Router Table Machines 2 01-14-2009 11:07 AM
Rockcliff Modifications alien_X Rockcliff Machine 5 01-10-2009 07:09 PM
ULS vent modifications cj8n@mac.com Laser Engraving & Cutting Machines 0 08-22-2007 06:44 PM
Super X3 Upgrades and Modifications dafowfidy Syil Products 16 04-04-2007 04:48 PM
BOSS 8 modifications jonny Bridgeport and Hardinge Mills 10 02-17-2006 12:13 PM
