Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-04-2009, 10:17 PM
bdring is on a distinguished road
Collimator Lens
I got my lens installed on my home built and it is working fine, but I have a few general knowledge questions.
Is there a top and bottom? Some of the sketches I saw on the Internet suggest both sided are convex, but the laser side is more convex (see Wikipedia). The actual lens was hard to tell. I shined a laser pen though and picked the way that looked better. It worked, but I would like to know the science behind this.
The lens is 55mm. Is this from the front, back, middle? I just experimented until I got the thinnest lines.
I can control my table via Mach3 so I backed off a little then draw a 4" long line while running up the height 1/4". I picked the thinest part and interpolated the best focal point from that.
Again...I got the result I needed, but would like to know the true definition of where the focal length is measured from.
My Build Log
DUAL FOCUS LENS (bifocal lens) bibi Laser Engraving & Cutting Machines 5 03-17-2009 06:03 PM
diy auto collimator???? the4thseal General Metal Working Machines 2 10-04-2008 03:05 AM
Problem- LENS SIZES SHADOW042 Laser Engraving & Cutting Machines 0 08-05-2008 10:29 PM
Looking for some Help Optic Lens tklock Laser Engraving & Cutting Machines 9 03-27-2008 06:39 PM
Where to buy lens? medved Mechanical Calculations/Engineering Design 5 12-30-2005 03:49 AM
