Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
  #13   Ban this user!
Old 10-04-2009, 08:01 AM
TheWorkshopGuy is on a distinguished road
Originally Posted by FlyGuy007 View Post
http://www.imajeenyus.com/v6/laser_c...lignment.shtml
This is a pretty good one, although we have it a bit easier because our tubes independently raise and lower front and rear.
Also check the other topics in the forum just a few down has a nice video link. But the page above ties it together better but it's nice seeing the video and then reading through the link a few times.
Mike
Thank you Mike,
I appreciate it. I will chechk them out.
David
  #14   Ban this user!
Old 10-04-2009, 08:40 AM
SkipW is on a distinguished road
David, here is the link to the setup vids.
http://www.cnczone.com/forums/showthread.php?t=89793
The mirror alignment starts part way through vid #2 and continues on #3.
Also, once you turn the power on you should be able to use the control pad on the laser to move the gantry and laser head to the 4 corners.
Alignment is a piece of cake, it's just time consuming. Make sure the machine is leveled and the vertical supports are extended to the floor and snugged down a little.
Skip
  #15   Ban this user!
Old 10-23-2009, 11:36 PM
cicigweike is on a distinguished road
Wink hi
hi, i am cici from G.weike company.
If you need technique support or machine have some problem, you
can send photoes and videos to the girl who sell you this machine.
Our machine guarantee for 1 years, and service is for free for ever.
Cici
E-mail: song@wklaser.com
www.wklaser.com
  #16   Ban this user!
Old 10-23-2009, 11:44 PM
cw3000 & cw5000
cw3000: water circulate only
cw5000: both water circulate and make cool
You can choose which chiller suitable for your working as follows:
1. laser power
60w can use cw3000, or water pump.80w/100w/more do need CW5000,
because it can make cool
2. working times
if you use the machine a long time everyday, you should use CW5000
3. weather tmperature
If your working room very hot at summer, you should use CW5000.
of course, if you can add some ice to the water drum frequently at hot
summer, CW3000 is ok.
The laser tube's temperature should between 20-30 degree, 25 degree is the
best for laser tube.
Cici
e-mail:song@wklaser.com
WK Laser LG900 Problems Buschy Laser Engraving & Cutting Machines 11 04-09-2010 08:51 AM
Need Help!- co2 laser (LG900) spacer777 Laser Engraving & Cutting Machines 11 10-24-2009 01:06 AM
Newbie- LG900 Laser Engraver TheWorkshopGuy Laser Engraving & Cutting Machines 11 10-24-2009 12:15 AM
