Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-19-2009, 03:56 AM
PaioX is on a distinguished road
Upgrade to powerfull laser lamp (WkLaser)
Hello,
I've a LC1280 with 80W lamp bought from Wklaser and I'm wondering to upgrade it with a more powerfull laser lamp. I know that I will change the power supply and probably modify the machine so the lamp can fit.
Did you know any site that sell laser lamp/power supply?How much can I improve Watts?150W?200W?
Many thanks and sorry for my english
Paride
Old 09-19-2009, 09:01 AM
zax15uk is on a distinguished road
You could upgrade to a 120W or perhaps 150W, but often the solution is to use 2 tubes and combining optics. I would suggest to look at the RF excited lasers, you would get better performance and life - but of course the cost if higher.
Zax.
Old 09-19-2009, 12:57 PM
SkipW is on a distinguished road
Paride,
Email wklaser.com They should be able to fix you up with a more powerful tube and matching power supply, and they can tell you if anything else is needed. Also check ebay.
Skip
Old 09-21-2009, 04:10 AM
hpc laser u.k is on a distinguished road
Smile
Paride,
You can do this no problem,
Look at changing to 120 w and power supply,
Make sure you have a good chiller.
Also ask about the 10,000 hour 150w tubes I am trialling these they will cut 3mm acrylic at 5.5 mtrs per min
Fastest I,ve seen for a while
Thanks Chris
Old 09-21-2009, 07:50 AM
Originally Posted by hpc laser u.k View Post
Paride,
Thanks Chris
I've asked Wklaser for more powerfull tube and the suggested me the 100W tube because 130W could cause some problems (why?!).
Can you tell me where I can find 150W tube and supply?!What machine did you have and how works these tubes?!
Many thanks
Paride
GE 388 Lamp lgreeves Fanuc 3 02-01-2010 02:20 PM
Problem- Upgrade from 60W to 80W laser tube bibi Laser Engraving & Cutting Machines 4 10-28-2008 03:56 PM
Makino FNC 60 spindle lamp jasnooks General Metal Working Machines 0 05-26-2008 10:23 AM
Would this motor be more powerfull than my current one? radicooldude General Electronics Discussion 7 05-20-2005 12:59 AM
Neon indicator lamp question The Wizard General Electronics Discussion 6 05-01-2005 11:28 AM
