Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-18-2009, 12:32 AM
Apexengineering is on a distinguished road
amada pulsar 2415 cut conditions
We recently acquired an amada 2415. It cut really well until several changes were made to the cut conditions. Does any one have some type of cut condition reference list for this machine? I need some starting points for feed rates, wattage, frequency, duty and etc. Anything would be appreciated and better than what I have now.
apexengineering
Old 02-28-2010, 08:39 PM
Bryden is on a distinguished road
we have a 2415, i could help you out with a few, although I'd have to write them all down manually, so let me know which ones you need specifically and I'll sort those out for you. In the back of the user manual there is a base setting chart too, btw.
Old 03-07-2010, 12:11 PM
2415 cut conditions
Bryden,
First of all thanks for your repy. I would like cutting conditions for the following:
18 ga. (.048) crs
16 ga. (.059) crs
14 ga. (.074) crs
16 ga. (.060) stainless steel
14 ga. (.075) stainless steel
I have looked at the back of the book and to me it looks like all of the default settings start out at maximum wattage, duty, etc.
sent you a pm
apexengineering
Old 04-13-2010, 07:57 AM
dewme5 is on a distinguished road
What is the wattage of your laser? I've just picked up an Amada 655 1500w, and there are several sample pieces that came with it. should be good for a start. I'll get back with those once I get into the shop.
Old 04-29-2010, 09:33 PM
amada pulsar
the amada pulsar 2415 is a 2500 watt
apexengineering
Old 04-29-2010, 09:52 PM
These are off of small notes on sample pieces. Should be self explanatory, but I'm not going to translate. (I'm going to assume metric settings
0.250" steel(crs?)
S=1500w
t=30hz
b=20%
f=200
o2=5kgf/cm2
0.0625" SS
S=1500w
t=2000hz
b=35%
f=1200
N2=8kgf/cm2
0.0625" MS
s=1500w
t=2000hz
f=2500
b=30%
PA=673w
o2=0.25
0.235" ms
s=1500w
f=1100mm/min
t=2000hz
b=40%
o2=0.75kgf/cm2
0.055" ms
s=1500w
f=400mm/min
t=400hz
b=20%
o2=1.8kgf/cm2
I apologize if anything sounds cryptic, but that's what I have to go with right now. Once the power company gets me 3-phase power, I'll have more info from the Amada people during installation.
Old 07-27-2010, 04:10 PM
djchrisondmix is on a distinguished road
how to take the deburr of a hole... i know it has a starting point and end point but it leaving me a burr specially on really thick material...anyone can help?!!!!! i have a really close tolerance...
Old 07-27-2010, 04:34 PM
Angry HELP!!! HOW TO TAKE THE BURR OFF ON A LASER CUTTING HOLE!!!!
I NEED HELP FINDING A WAY TO TAKE THE BURR OFF ON A LASER CUTTING HOLE... I KNOW IT HAS A STARTING AND ENDING POINT.. EXAMPLE WHEN I CHECK WITH CALIPERS HOLE CHECKS .125 BUT WITH GAUGES IS UNDER SIZE BECAUSE OF THE BURR THE LASER LEAVES.... ANYONE CAN HELP ME!?
Old 07-27-2010, 09:27 PM
I'm making the assumption that the burr you are referring to, is on the side of the cut, and not the dross below the cut.
The size of that burr, is just a factor of your cut conditions. If you need a perfectly smooth hole, then you are not going to get that with a laser.
Pulse freq, pulse duration, speed, assist gas, focus, and power all have an effect on that burr. When conditions are the best they can be, that burr will be minimal, but still present.
T1 101 missing conditions nastek Mazak, Mitsubishi, Mazatrol 1 04-10-2010 02:23 AM
Need Help!- Amada Pulsar 2415NT Post for MCam X3 stpierrenb Post Processor Files 3 08-09-2009 04:25 PM
Need Help!- has anyone set up cutting conditions laserkey Tutorials 0 04-05-2009 06:01 PM
Amada LC644/667II cutting conditions help!!! Marian1972 Fanuc 0 11-24-2008 04:39 PM
Working conditions Geof Safety Zone 1 12-22-2005 11:57 AM
