Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-17-2009, 11:03 AM
spotbox is on a distinguished road
DLL Version does not Match
Hello
I have a new laser machine with MPC6515 card.
How can I Fix This error messege on machine Display:
DLL VERSION DOES NOT MATCH FIRMWARE VERSION
Thank you
bye
Old 09-17-2009, 12:57 PM
SkipW is on a distinguished road
Originally Posted by spotbox View Post
Hello
Thank you
bye
Here is the address to the MPC6515 manual from the manufacturer. Maybe the answer is there?
http://www.leetro.com/english/leetro...0%20Manual.pdf
Skip
Old 09-19-2009, 07:25 PM
kewlkiwi's Avatar
kewlkiwi is on a distinguished road
MPC6515 firmware files
Hello
If you are using LaserCut then look for a program in the same folder called MPC05Ver+MO5.exe (or similar)
With Laser switched on, run this exe and it will tell you the version of the DLL and the version of the Firmware in the laser.
Of course, the computer needs to be connected to the laser via the USB cable when you do this!
Bob
Old 09-19-2009, 08:08 PM
version info
Thanks Bob. I had never ran that file before and it was named just as you said. I've never had any error messages either though.
Just so spotbox has an error free machine to compare his to, this is what running that file showed me. My machine is 2 years old so the versions may be different now.
Spotbox, let us know what running the file shows you.
Thanks,
Skip
Old 09-20-2009, 03:40 AM
kewlkiwi's Avatar
Other things to play with!
I have the same versions as you Skip..
While you're in that folder, you may like to have a look at the 'language.ini' file where you can correct a few spelling mistakes, and add your own (or company) info.
Item# should be
7097 Rotate
177 [Your name]
178 [Your phone]
179 [Your website]
61462 Engraved polyline must be closed
etc etc.
I think there are at least two "Rotal's" which should be Rotate, while 7040 mentions a knife, that may actually be 'laser' - dunno if it's used though. Several sections look like they are repeated, so the file probably needs a good cleanup - but maybe it's better to leave well alone as far as that goes! I only changed the ones that were annoying me
Not sure what an 'Auto jude director is' but that's in there...
Have a good look through that file, and you will probably find several Chinglish words that could be changed (make a backup copy first, of course)
'Conner power' should be corner power.
Bob
Old 09-20-2009, 09:39 AM
Thanks Bob, I'll check that out. The only change I have made (so far) was to the start up graphic. Mine now says "Software X" in generic black text with a white background when it starts.
I actually think my LaserCut 5.0 is pretty good software. It has many of the features that I see owners of some US machines wishing they had. I would like to upgrade to a newer version sometime though just for the ability to arc into and out of a cut. I think that would be a handy feature because depending on the material I'm cutting, I occasionally get a slight mark where the cut stops.
Skip
Looking For CNC To Match A Few Different Scenarios carpenma Benchtop Machines 8 08-04-2009 12:59 AM
match 3 , powermill y 4 eje Diegone Spanish CNCzone 0 04-18-2009 07:03 PM
H&T don't match? Donkey Hotey Haas Mills 37 03-23-2008 09:30 PM
VCarve Pro Trial version 3.0: any newer version? monte55 Vectric 2 12-11-2006 06:12 PM
X1 and X2 mix and match acondit Benchtop Machines 14 12-05-2005 04:11 AM
