Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-16-2009, 01:10 PM
etienne delcuve is on a distinguished road
Align mirrors ?
Hi everybody,
have someone a trick or a link to align perfectly the mirrors (not inside the tube) on a engraver (rabbit like).
The mirrors are misalign after I dismantel my engraver to increase the graving
area.
thanks
sorry for my english
Old 09-16-2009, 02:00 PM
SkipW is on a distinguished road
Originally Posted by etienne delcuve View Post
Hi everybody,
area.
thanks
Here you go! And your English is fine.
There is also parts 3 and 4 of this setup video on youtube.com The mirror alignment starts at about 5:40 minutes in this video and continues on video part 3 if I remember correctly.
Part 3
Hope this helps you.
Skip
Old 09-16-2009, 02:44 PM
Thank you
Hi SkipW,
thank you for your reply.
I 'll go have a look on the videos
Old 09-17-2009, 10:18 AM
You are welcome.
De groepering van de spiegel kan een pijn in de ezel zijn.
(mirror alignment can be a pain in the a$$... translation from Babel Fish translator)
Let us know how it goes.
Skip
Old 09-17-2009, 04:44 PM
thank you SkipW,
I have tried a little to align mirrors. It's not easy with this chinese engraver. the mirror mounts are bad. I thing i'll buy first new "customized" mirror mounts I found here:
http://cgi.befr.ebay.be/CO2-Laser-re...4.c0.m14.l1262
Before I dismantel the machine I was able to cut 3mm MDF wood in 1 pass.
Now, I must make 2 passes to cut 2.5 mm MDF !!!
On one of the mount (the first one, close to the tube), I only have 2 screws that you can turn with fingers. the thirth one is a "alen" screw, impossible to
setup unless I dissassemble the plate on witch the mount is fixed.
the others mounts have the 3 "finger" screw !!
I' ll try later when I received the new mounts.
thanks !
PS: In Belgium, a so little country, we have 3 langages: French (it's mine),
Nederland (same langage as Holland poeple) and Dutch (same as in Germany).
That you to translate in Nederland, I have understood but my favorite langage after French is English.
Merci beaucoup
Dank u well
vielen Dank
Thanks a lot
Newbie- engraving mirrors denbruno_09 Laser Engraving & Cutting Machines 21 Yesterday 04:07 AM
Align Honing or Align Boring ? jonbanquer General Metalwork Discussion 10 11-09-2008 10:33 AM
Where to get mirrors FAST! Mrebeiro70 Laser Engraving & Cutting Machines 13 11-08-2007 06:47 AM
Mirrors and Lens Furlan Laser Engraving & Cutting Machines 1 03-30-2007 09:52 PM
mirrors miljnor Laser Engraving & Cutting Machines 7 11-20-2006 06:54 PM
