Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
  #13   Ban this user!
Old 10-01-2009, 08:00 AM
rcpilot82 is on a distinguished road
Glad to see your up and running! how do you calibrate the mirrors? Is this a normal setup procedure or maitenence task? The more time I spend in my workshop, the more uses I find for a laser. I am starting the information gathering stage to design a 50% scale RC Monocoupe airplane and this laser would be awsome for cutting out all the parts. It will take me about a year to finish the design process and cut the first kit. If all goes well, I may have to add it to my list of kits to sell.
Necessity is the mother of all invention (unknown)
My club home page www.lhmac.org
  #14   Ban this user!
Old 10-01-2009, 09:40 PM
Gone Cruising is on a distinguished road
Actually I should have said "aligning the mirrors". The laser beam exits out of the tube and reflects off of the first mirror, then to a second and then to a third which directs it to the lens.
On my machine the mirrors I believe are 50mm in diameter. I taped a round piece of cardboard in front of each mirror, hit the laser button which sends a laser pulse to see where it hit's the first mirror, leaving a small burn spot. If not at the center you make small adjustments to the mirror. After the first one is aligned and the beam hits center you remove the cardboard or chip cover and see where it hit's the second mirror...then the third.
It's an easy process...just time consuming to get it right the first time.
Good luck on your quest for a laser. It should come in quite handy for what your doing!
Kirk
  #15   Ban this user!
Old 10-02-2009, 10:58 AM
Hey, I just checked out the legacy lasers site and see a new line of lasers on the bottom of the products page! looks like they got a 2 year limited warranty, and new paint job. anyone know more about this series. looks like the 1100 series would work for me also. Anyone know the differences between the 1200 and 1100 series?
  #16   Ban this user!
Old 10-02-2009, 11:03 PM
Looks like it's just a newer updated version, but with a longer warranty. Call or e-mail Dean, he will be glad to help answer all your questions.
  #17   Ban this user!
Old 10-04-2009, 11:30 AM
Thanks!, Belive it or not I had a PM from Dean shortly after posting explaining the details. Dean, you get a thumbs up in my book.
Kirk, please keep posting your projects here. I am curious to see this laser in action.
  #18   Ban this user!
Old 11-09-2009, 01:48 PM
How about an update on the Lasers!! Also, Does anyone have the shipping crate measurements or know if it would fit in an 8ft bed with a tall cap, or is a trailer needed?
Tags
engraver, laser, legacy, legacy lasers
LEGACY CNC MILL RIPPING OFF YOUR MONEY! ruawake Commercial CNC Wood Routers 25 04-04-2012 01:22 PM
Legacy Mill with DynaCNC upgrade Hikingstaffs DynaCNC 1 01-10-2008 09:25 PM
Legacy DOS program capability preservation NC Cams General CNC (Mill and Lathe) Control Software (NC) 56 12-18-2006 08:18 AM
Fadal legacy (88-HS) troubles Andrew_K Fadal 7 12-11-2005 05:50 PM
Dash 3 Legacy software issue ZachB Fadal 0 09-15-2005 02:36 AM
