| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| Stepping Motor Required Hello , I am in need of a Stepping Motor part number 57BYGH803 which comes out of an IE 500 laser engraver. I live in Canada , anyone have any contacts as to who I could try in obtaining one of these motors? Thanks very much, Terry |
| It will be similar to this motor http://www.kelinginc.net/KL23H276-30-8A.pdf http://www.kelinginc.net/NEMA23Motor.html |
| Hi there thanks for the info and yes similar however not quite the same allthough one of these would probably work but a little risky to the mounting of it , I have the defective motor so really trying to duplicate it if possible. Terry |
| Terry, Google is your friend... http://www.yeno-electronics.com/prod...?ProductID=571 http://www.jameco.com/webapp/wcs/sto...oductId=237631 Since it is a NEMA23 stepper motor you could replace it with any other NEMA23 with the same specs, the mounting would be the same as NEMA23 specified the size and mounting hole locations as well as other basic dimensions. The length will change depending on how many stacks, but so would the torque and other factors. Zax. |
| Terry, I'm not sure what you are looking at, the link should take you directly to the correct p/n (57BYGH803) for $29.30. Steppers can be travel limited by mechanical (physical stops) or software (programmable limits) but not within the motor itself since it doesn't know where it is. Software has to 'home' the motor to a stop or electronic limit (opto or mechanical switch) prior to counting steps. Zax. |
Terry |
| Terry, The motor drivers should be located behind the lower right cover. What is the actual issue? I've seen very few failures from the motor drivers unless you push the gantry around a lot and create back EMF - and even then you'd have to be unlucky. The simplest way to check is to swap the motor cables. Zax. |
#10
Ok the actual issue with the motor is when I send power to the stepper motor from the pc board on the laser engraver it runs very slow, laboring and that happens on both directions clockwise/counter clockwise. The other stepping motors in the machine work fine and when I turn the shaft by hand they feel the same as the one thats laboring so im pretty sure its not a motor issue..I am running the LaserCut 4.0 software and recently I had done some Machine config changes and maybe its a coincidence but it was shortly after I done those changes this motor issue arrised..Could the Machine config settings play a roll in this you think? |
#11
| It certainly could be the configuration - in fact this sounds most logical. Is this the table lift or one of the axis? Say it's the Y-axis, if you move it from the origin (0) to a set point does it move the correct distance? If you then move it back to the origin does it end in the exact location it started? If so, it's the configuration. Here's why. The stepper has fixed increments, so for it to run slow it is either losing steps (could be due to mechanical, motor or driver fault) or being sent slower pulses. When steppers lose steps they do not recover them unless they have encoders (rare) so it will be short of the commanded distance. Zax. |
#12
Hi Zax, it is the table lift and im sure your right on target with what your saying. I should have known better if it aint broke dont fix it..I was trying to make axis adjustments..To answer your question about the y axis distance of travel yes your correct it ends in the exact location it started...So now a matter of resetting the machine config or have a recommendation what I should do? |
| Stepping Motor Sanyo-Syn 103-820-2 | chockstef | Stepper Motors and Drives | 5 | 06-10-2009 05:05 AM |
| help me in stepping motor | ibrahem_mo | Mechanical Calculations/Engineering Design | 0 | 08-28-2007 05:22 PM |
| Stepping motor control | Zeekh | General Electronics Discussion | 0 | 12-10-2006 01:21 PM |
| Stepping motor control... | Zeekh | Stepper Motors and Drives | 0 | 12-10-2006 08:55 AM |
| Where to buy stepping motor | birdofcnc | Stepper Motors and Drives | 9 | 01-12-2006 06:21 PM |
