Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
  #13   Ban this user!
Old 08-31-2009, 03:57 PM
terry32506 is on a distinguished road
Originally Posted by zax15uk View Post
It certainly could be the configuration - in fact this sounds most logical.
Is this the table lift or one of the axis?
Say it's the Y-axis, if you move it from the origin (0) to a set point does it move the correct distance? If you then move it back to the origin does it end in the exact location it started?
If so, it's the configuration.
Here's why. The stepper has fixed increments, so for it to run slow it is either losing steps (could be due to mechanical, motor or driver fault) or being sent slower pulses. When steppers lose steps they do not recover them unless they have encoders (rare) so it will be short of the commanded distance.
Zax.
Looks like I am making some headway , I changed the Z Need Pulse back to 6400 from the previous setting of 1700 and thats turning the motor much better so will put it back together and see what happens.
  #14   Ban this user!
Old 08-31-2009, 05:47 PM
zax15uk is on a distinguished road
Good news, glad you've got it working again.
Zax.
Stepping Motor Sanyo-Syn 103-820-2 chockstef Stepper Motors and Drives 5 06-10-2009 04:05 AM
help me in stepping motor ibrahem_mo Mechanical Calculations/Engineering Design 0 08-28-2007 04:22 PM
Stepping motor control Zeekh General Electronics Discussion 0 12-10-2006 12:21 PM
Stepping motor control... Zeekh Stepper Motors and Drives 0 12-10-2006 07:55 AM
Where to buy stepping motor birdofcnc Stepper Motors and Drives 9 01-12-2006 05:21 PM
