| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| Hello, First let me start by saying how NEW I'm to laser cutting technology. I have managed to build my first laser and CNC machine. Go figure! The CNC laser is working fine. Currently I'm using a reed switch to turn the laser on and off as it travels along the Z axis (up and down). This process works well, but a little ineffecient, because of the laser has to travel up and down along the Z axis to trigger the reed switch to turn the beam on/off. What I was wondering, is there a method, something that I can do, which allows the Z axis to be in a fixed position above the matrial and turn the laser on and off at each cutting point without moving the laser up and down along the Z axis? I'm using Mach3 Pro and LazyCam Pro. One more thing. Does anyone know what temperatures are normal for 100w, 200w, 300w, 400w lasers? Water and gas temperatures? I designed this laser to output these 4 settings and want to intergrat a thermostat system to shut the laser down in the event of over heating. I'm currently cooling the gases by rapid exchange of the gases and water through cooling systems that I setup. So far so good. Maximum out put of this laser is 5kW DC pulsed (83,000v @ 60mA=5kW. Approx.), which makes this laser a usable 500w cutter. Scary, isn't it? Well it is to me! Thanks in advance for any help that I can get. Robert Last edited by r.rooster; 08-22-2009 at 09:46 AM. |
| Look into Mach's 2.5D mode. It triggers an output on any G-Code Z move, but does not actually move an axis. Some people have used the Z direction too. Set the down bit to turn on the laser then the return up will turn it off. I am working on my own setup and doing some in depth studies on power control methods. I am just getting started, but you check out my progress. http://buildlog.net/cnc_laser/mach_laser_power.html |
| Need to replace Dynapath 20 control with new control | Cycle Start | Knee Vertical Mills | 3 | 08-08-2010 04:14 PM |
| Need Help!- Seig x2 Speed Control and c6 Control Board | skmetal7 | Benchtop Machines | 2 | 04-21-2008 04:17 PM |
| 15i control help for (AiCC) (hpcc) high precision contour control programming | gibbsmaster | Fanuc | 2 | 12-28-2007 10:57 AM |
| Using Flashcut CNC Spindle rotate card control to control laser power | pyroplotter | FlashCut CNC | 0 | 10-15-2007 10:46 PM |
| BobCADCAM Layer Control / Snap Control | jonbanquer | BobCad-Cam | 0 | 01-21-2006 04:10 PM |
