Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
  #13   Ban this user!
Old 08-18-2009, 05:56 AM
Pierke is on a distinguished road
Wink
Hello Anton,
i'll hope that Jiachen can help you with the video.
Maybe jou can put the video also here?
Pierke
  #14   Ban this user!
Old 08-18-2009, 12:26 PM
Anton D is on a distinguished road
Problem with my video (Lost the firewire cable!!)
Here is a photo showing the extent of the problem
Name:	y axis problem.jpg‎
  #15   Ban this user!
Old 08-18-2009, 12:43 PM
zax15uk is on a distinguished road
Anton,
I have seen similar problems caused by settling errors (PID feedback loop) on servos but this can't be the case with stepper motors.
This looks more like a controller problem (firmware) or possibly from driver feedback (electrical noise), but since you said it seems rough mechanically I guess it could be caused by resonance or slack in the other axis.
If you do a line is it straight? (without moving the other axis... so just a line in X or Y independantly).
Zax.
  #16   Ban this user!
Old 08-18-2009, 02:08 PM
Zax.
straight line on x only
straight line on y only
and interestingly straight 45 deg (x+y)!!
Anton
  #17   Ban this user!
Old 08-18-2009, 05:19 PM
Actually that makes sense... if you cut a square, do you get these deviations at each corner? (as the y-axis stops and the x-axis begins etc)
If this is a firmware issue I would think the manufacturer or local representative has experienced this before, so hopefully they can help. As I said, it could also be from belt/cable stretch, slowing the system down should correct it if this is the case. There may be some adjustment of the tension that will fix the problem, or you may need to replace the belts.
Zax.
  #18   Ban this user!
Old 08-19-2009, 11:23 AM
Found the problem!! Had a poke around in the machine setup sub menu's (The one's marked not for use by the user!) The head travel speed had set itself to 99999.99mm/s.
Jiachen recently provided me with the new version of the process software which I have had a few problems with, it still will not cut and arc! Surely the new software can't have changed the dsp settings? I would like to go back to using my tried and trusted 2007 version of the process software(which I have) The problem is that I have removed the Corel Visual basic GMS file from my system and my backup disk is corrupted(Not able to recover).Does anyone have the 2007 software GMS file for this machine
Thanks for all your time guys, You have all been a great help.
Anton
  #19   Ban this user!
Old 08-19-2009, 02:25 PM
Great news Anton.
I'm glad you found the problem, like I said "slowing the system down should correct it"
Zax.
Add US made laser module to Chinese laser? glintid Laser Engraving & Cutting Machines 13 05-02-2012 02:43 AM
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
Need Help!- Questions for you laser guys - building own laser control Sputnik Laser Engraving & Cutting Machines 2 05-18-2009 08:46 AM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
