Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-14-2009, 12:54 PM
Ingallspw is on a distinguished road
G-code Establishing a temporary 0,0 from a master 0,0
I'll try to keep this breif and to the point.
Using a 4 x 8 sheet of steel, I am trying to cut a complex disk that constantly change in diameter. It has a circular array of a complex shape in it that stays the same from disk to disk. The position of that cut changes per disk diameter.
What I want to do is program a sub that cuts at a different 0,0 than the original home location of the part, rotate it 11 times, but keep it all tied to the original 0,0.
Does that make since?
Keegan
Old 08-14-2009, 01:10 PM
HuFlungDung's Avatar
Moderator
Does your control offer a G52 workshift? You can search the forums for that term G52 and I think you'll find lots of discussion on it. Its usage is different than the regular work shifts, as you can call new datums with it, within your program. In this case, because you know where your primary datum is, and the exact relationship of all the others to that, G52 should work well.
Tags
g-code, g53, g91, laser, program
Need Help!- Re-establishing CS position? jerseyTom Fadal 2 08-04-2009 10:36 AM
drawing off a temporary origin CNC-Hammer Autodesk Software (Autocad, Inventor etc) 3 03-17-2009 05:02 AM
re establishing arc bvweld DynaTorch 2 09-24-2008 01:08 AM
Error code ? Replacement cost for a GNO master board? Skyshark Fanuc 3 08-21-2007 06:24 PM
g-code with master cnc utilities SHEDCNC G-Code Programing 6 04-03-2007 06:15 PM
