Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-01-2009, 06:14 AM
niklasn78 is on a distinguished road
My laser do not cut strait
Hello all experts out there
i have purcase i Golden sign 9060 laser engraver 60W
And i have a problem that it cut a line that is inconsistent in one direktion
i have focus my mirrors as the manual says all lenses is hit by the laser in the middle in max and min movment.
I attach a picture of my problem
Any suggestions
Thanks in advance
NiklasClick image for larger version
Name:	no strait line.jpg
Old 08-01-2009, 07:06 AM
Litografa's Avatar
Litografa is on a distinguished road
Hello, Niklas
First of all do you have good grounding? If yes and you are sure in grounding quality - check belt tension. If everything is OK with belts - check motors.
How it was happened - from the beginning (first job) or after certain time of running?
Do you have possibility re-write your firmware?
Old 08-01-2009, 09:55 AM
hello and thanks for your reply
i have connect the electric cabel to the machine whith is grounded in my electric socket in the wall.
But it is a groundcabel from the machine exiting on the bottom, i have not done anything whit it because i thought i have enough ground from my electric installation in my wall.
what is firmwire?
Regards
Niklas
Old 08-01-2009, 10:03 AM
Litografa's Avatar
Better make separate grounding for laser. I don't know how it possible in Sweden, but in Lithuania we have copper bus in each electrical distribution panel (in office, home and etc). If you have laser in some kind of industrial building - copper band schould be inside wall - usually 45 cm from floor (but not sure that this is international standart - work in many countries well).
Firmware is programm which is inside your motherboard. On GCC lasers you can upgrade/re-write firmware from your PC. I expect that this feature schould be in your laser also.
Old 08-01-2009, 11:25 AM
zax15uk is on a distinguished road
Niklas,
It is difficult to see from your picture, but you say the line in X direction is not straight. Do you mean it is wavy?
I would check the Y-axis does not have excessive play (movement) in it, due to a loose belt, gear or coupling.
Are you sure the material is not moving, either from cutting or vibration?
The other thing I would check is the lens assembly (head), to ensure it is not loose and able to move on the ways. If it can twist this needs to be adjusted.
Zax.
Old 08-01-2009, 11:32 AM
LuAn is on a distinguished road
In what way is it inconsistent? I can't tell from your image. It looks a bit like the line is thicker at the left side than at the right. Is this what you mean?
Old 08-01-2009, 12:07 PM
Thank you for all help i test to put down a kopperpole in the ground and attatch my groundcable to it and it do no diffrense.
I attach 2 picture of a work i did in my machine and i also attach my cutfile if any can se if it is samthing wrong there.
i do my cadwork in Rhinoceros and save it too .AI and open it in Coreldraw X3 and save it as .PLT open it in my laserprogram and save it as .MOL then cut it.
The program is golden sign53.
i tested to use laserinput in corel draw X3 but ven i have set my start point in upper right corner on my workpeace and click start the laser got crasy and
in fast movment too right and bouns in the stop then too the back of my mashine same there.
Can this have same factors i mean in drivebelt?
My workpeace is clamp dawn with scoth tejp and i have check my head and if i move it i will move the hole trolle the small flex is the tollerense in the rollers on the guidelines.
and yes it is a wavy line i say it differ 1mm too each side in a wavy pattern.
Regards
Niklas
Old 08-01-2009, 12:11 PM
the pictures is god too have
ID:	85446   Click image for larger version
Old 08-01-2009, 12:46 PM
I would suggest reducing the speed, to see if it corrects the problem.
Zax.
Old 08-01-2009, 12:50 PM
I was going to suggest that one or more of the rollers on which your head trolley might be damaged, non-circular, off centre, or have some dirt on it. However if there is slack such that the trolley can wobble, that is probably the problem. My machine, a different model, has some small screws that can be used to adjust this such that there is no play in the trolley. If your head/trolley moves in the X direction on the beam, there should be no play in the Y direction.
  #11   Ban this user!
Old 08-01-2009, 03:06 PM
Pierke is on a distinguished road
Smile
Hello Niklas,
when all the power is off, check (by hand)
The x-axis and Y-axis, when you try to move for- and backwards.
Is there a little gap (movemend??)?
Possible is a screw on the gear off your steppermotor is loose, or to loose.
I think its a mechanical problem.
Pierke
  #12   Ban this user!
Old 08-02-2009, 08:04 AM
Ok guys
pierke
Now i have tested my gap and i will say that if i try to move it it vill move the belt no gap or movment that i can se
i check my steppmotor it seams ok.
Luan
i have check my rollers clean it and test to move it and it seams to roll nicely whitout any tveaks or stop.
Zax
I tried to reduce speed no differense.
I have tried to tighten my belts so now i have mayby 1mm slack ( quiet tight and hard) hw tight can i have them?
I tested after it and i attach a picture of it no god result as you can see.
i also attach my cutting file from earlier post
is ther anything wrong with my program or file?
Regards
[ATTACH]files.zip[/ATTACH]Niklas
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 03:44 PM
Need Help!- Questions for you laser guys - building own laser control Sputnik Laser Engraving & Cutting Machines 2 05-18-2009 09:46 AM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 11:17 AM
Add US made laser module to Chinese laser? glintid Laser Engraving & Cutting Machines 9 11-27-2007 01:31 PM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 03:39 PM
