Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
  #49   Ban this user!
Old 08-07-2009, 11:38 AM
SkipW is on a distinguished road
Originally Posted by niklasn78 View Post
I ask before how I do to install these drivers and I didnīt fully anderstand haw i should do it.
Ithink it was done when I install my program, however I am happily to install them again if I now How,just in case....
I tock apart my X beam and head today and I cant se anything wrong whit it no dents or anything that can do my lines vavy.
I spoke whit my seller today and he say that my laser was installed whit lates firmware file before chipping.
Niklas
Niklas, I have LaserCut 5.0 so a newer version may be different. Here is how it is done in 5.0:
With laser power on, open the LaserCut software and click the printer icon. This should open the "Laser Output" window.
Click the "Stand Alone" tab.
Click "Download CFG".
This should send the configuration file to the laser, and the laser should make a beep noise to tell you it received it.
You only have to do this one time unless you change your configuration settings in LaserCut.
I don't know if this is your problem or not but it is worth a try.
Skip
Add US made laser module to Chinese laser? glintid Laser Engraving & Cutting Machines 13 05-02-2012 02:43 AM
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
Need Help!- Questions for you laser guys - building own laser control Sputnik Laser Engraving & Cutting Machines 2 05-18-2009 08:46 AM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
