| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| Hi everybody, I am from Belgium and I recently buyed and received this laser engraver : http://cgi.ebay.de/ws/eBayISAPI.dll?...:X:RTQ:DE:1123 The explanations tells that it can import .dxf format. With the software delivered (NewlySeal 12) I can only engrave dot by dot and I cannot cut VECTORS. The seller is a liar, and making seals don't interest me! that the reason why I want to try Linkmotion at http://www.solustan.com/ but I have to furnish a max of information about this machine. The only things I know is: - it comes from China - drived by LPT port - drived by Newlyseal as "rabbit40" - I have made pictures of this machine Can somebody help me in my quest ? PS: see the job I have made with an other machine and an other laser |
| Going off the photos of the circuit boards, this machine looks to be almost exactly the same as mine: http://www.andyslater.com/laser-cutting/ I managed to destroy the controller board on mine so I replaced it with controllers from RoutOutCNC and Mach 3 software. Details at the site above. As a result of doing this, I have a spare copy of NewlyDRAW, with soft dog, that I don't need (and which might be of interest to you). |
| Yes, I agree he is either a liar or misinformed. The listing says 50W, there is no way it outputs close to that - probably between 35 and 40W is realistic. Anyway, the problem is you have NewlySeal and require NewlyDraw. Perhaps you could do a deal with LuAn for the software. I don't know if your USB dongle will work with it or not, but if you PM me with your e-mail I can send you the installation files for NewlyDraw. It will allow you to do all you need, cut vectors and engrave. The other option would be to replace the controller card with standard step/direction drivers and use Mach3, EMC or similar. Zax. |
| I checked that webiste, it is a stamp making machine, very cheap! Use newly draw or moshi software, LPT port! The speed is very low, not good for engraving! You had better choose laser engraving machines! Alice sukelaser@hotmail.com www.sukelaser.com |
Did this get sorted out? Did the NewlyDraw software work with the NewlySeal dongle? |
| unfortunately, the dongle of Newlyseal don't works whith Newlydraw. I have asked the seller about .dxf import (for Vector cutting) and normally, he will send me Newlydraw. For VECTOR cutting, what kind of software can I use who should be compatible with the parallel input of my laser engraving machine ? I work with CorelDraw for my cnc mill but I don't know how to send instructions to the parallel port for the engraver. (maybe it's not possible !) thank you again. |
| So is he going to send it? If not, send me your postal address (you already have my email address) and I'll work out a cost for sending you the one I have spare. Last edited by LuAn; 08-02-2009 at 11:35 AM. Reason: Correcting a mistake |
#10
| Etienne, You would create the designs in Corel, as you do for your mill and then import into NewlyDraw as dxf. NewlyDraw will then output to the laser. You do not need any intermediate steps to create gcode etc, although you do sometimes need to consider the kerf and adjust accordingly. Zax. |
#11
| saleCNC laser engraving machine and CNC woodworking machine | zhangrui1588 | Laser Engraving & Cutting Machines | 3 | 05-08-2011 04:54 PM |
| Another machine rigid tapping (stepper machine) | samco | LinuxCNC (formerly EMC2) | 10 | 04-10-2009 08:21 PM |
| sell CNC Woodworking Machine,CNC Advertising Machine | zhangrui1588 | Product Announcements & Manufacturer News | 0 | 05-30-2008 09:43 AM |
| Deep Groove Taig machine would it be a good starter machine | Fritzie15 | Taig Mills & Lathes | 0 | 09-20-2007 10:37 PM |
