Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 07-27-2009, 07:22 AM
beavis is on a distinguished road
Question Trumpf/Haas-laser.
Hi you all, last week I bought this unit, it seems to be a laser-unit, but it doesn't make real sense to me, where does the beam evolve from, the white circle which shows is some kind of ceramic disc, it is mounted in the aluminium heatsink, which contains 2 items with 2 wires coming out of them, which are serially connected and show hardly any resistance.
And more important, there are no holes in the cavity where the disc is inserted.
There are 30 small black things on the vertical pcb, which are serially connected in a set of 24 and 6, which seem to be diodes, because they only show conductivity in 1 direction.
The electronics are made by Haas-laser from Switzerland.
Has anyone ever seen this kind of device?
ID:	85087   Click image for larger version
ID:	85088   Click image for larger version
Old 07-27-2009, 08:44 AM
Litografa's Avatar
Litografa is on a distinguished road
Please don't be angry on me, but for you will be better call Haas and ask for support. Looks like you do not have enough knowledge in this area.
Trumpf Vectormark DIFF OVER Laser Engraving & Cutting Machines 1 09-09-2010 07:17 AM
Need help with a 2530 trumpf laser BUD B General CAM Discussion 9 06-18-2010 08:35 AM
Fabriwin material files for Trumpf Laser BROCD Laser Engraving & Cutting Machines 5 06-10-2009 12:55 PM
Need Help!- Disable Height Regulation on a Trumpf Laser? CLT-Tech Laser Engraving & Cutting Machines 9 03-04-2009 11:27 AM
Trumpf Laser m/c .. 2025, 2030 ... s_viswesh Laser Engraving & Cutting Machines 0 09-11-2007 07:46 AM
