Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 07-23-2009, 01:19 PM
Pierke is on a distinguished road
Angry Spot Size measuring?
Hello,
how can i measuring the spot size of my laser?
Pierke
Old 07-23-2009, 03:45 PM
zax15uk is on a distinguished road
Burn a hole in a piece of paper, use just enough power to produce a clean hole and ensure the beam is focused.
The next challenge is to measure the hole, a microscope with reticle would be ideal.
You can get pretty accurate results.
Zax.
Old 07-24-2009, 02:27 AM
Litografa's Avatar
Litografa is on a distinguished road
We measure spot size on Alumamark. With use of paper mark is slightly bigger than real spot size due paper burning. With Alumamark you have practically exact size of dot. Of course perfect focusing is necessary.
Old 07-24-2009, 07:52 AM
Actually the paper method with very low power produces accurate results when compared to electronic based measurement system. It even shows the halo or HAZ (heat affected zone) around the focused beam.
You will of course need a sufficiently high mag scope with measurement capability to determine the actual spot size vs. the halo area.
I have not tried Alumamark but that should work the same way, just with more power required.
Zax.
Old 07-24-2009, 07:57 AM
Litografa's Avatar
And what do you think about glass or stone? Looks like on glass will be best results for accuracy of spot measurement?
Old 07-24-2009, 07:58 AM
Smile
Heloo Litografa & Zax,
to measure the spot size, must i give only a short schot, or must i engraving a line?
Pierke
Old 07-24-2009, 08:03 AM
Litografa's Avatar
I am using single shot.
Old 07-24-2009, 08:51 AM
Exactly - single shot.
It can be done by manually firing the laser at low power, just make the pulse as short as possible or if your system can send a single pulse from the software that is better.
Zax.
Old 07-25-2009, 04:26 AM
kewlkiwi's Avatar
kewlkiwi is on a distinguished road
Cut a slot, and use feeler gauge set?
Bob
Old 07-25-2009, 09:15 AM
Bob,
That would work. I was trying to think of a simple way for someone to measure it without a scope or other equipment.
I have access to so much technology I couldn't see the 'simple' method.
Thanks,
Zax.
  #11   Ban this user!
Old 07-25-2009, 01:32 PM
Smile
Thanks to all for the verry good info.
I'm glad that i can try it on several ways.
Pierke
  #12   Ban this user!
Old 07-28-2009, 03:27 AM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
I just use a very powerful magnifying glass and measure the spot size with a dial caliper. It's accurate to about 0.0005".
I place a piece of thin cardboard bent over at 1 end to form a ramp about 10mm high and 50mm long then burn a spot every 5mm up the ramp. Then all I do is find out which spot is the smallest and measure that against the height from the lens to also get the focal distance for setting up the laser head.
regards
Richard.
I am not completely useless.......I can always serve as a BAD example.
When do you stop measuring rapids in IPM and start measuring in G? slashmaster Benchtop Machines 10 07-08-2009 05:42 PM
spot welding force2@nc.rr.co Welding, Brazing, Soldering, Sealing 1 05-25-2008 10:41 PM
spot welding mog5858 Welding, Brazing, Soldering, Sealing 3 03-10-2008 03:45 PM
Spot welding ??? skipperspride Welding, Brazing, Soldering, Sealing 1 02-17-2008 12:27 AM
mig as a spot welder? blighty Welding, Brazing, Soldering, Sealing 3 01-16-2008 05:28 PM
