Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-30-2009, 03:46 PM
StarLoc is on a distinguished road
3040 laser and Turbocad to Newly draw.....
Im using a 3040 with newlydraw, normaly with no problems but only with files i have done some time ago, today i was drawing some new parts on turbocad, saved as a DXF ( as i always do , but havent drawn any for about 6 months so cant remember much!) ,
then i changed over to the other computer and loaded into newlydraw , nornaly this is fine but on loading the DXF i now have the part i want to cut ( drwn with spline by control points ) , i am sure the eliptical shape i have drawn normaly cuts out, but this time i have the elipse surrounded by a frame of angled straight lines forming a frame between the control points as well as the elipse, when it cuts it cuts both
Does anyone know / have a guess at What i have done! , why is turbocad exporting the control point frame, it doesnt show on the drawing in turbocad , or is it a setting on newlydraw i have changed?
Old 06-30-2009, 04:52 PM
zax15uk is on a distinguished road
In TurboCAD when you save as DXF, click on 'Setup' and make sure you have AutoCAD R12 selected. I also suggest checking 'Unblock' and 'Explode Text' for maximum compatibility with NewlyDraw.
Zax.
Old 06-30-2009, 05:55 PM
Thanks, thats sorted it, i also had it drawn as grouped parts,it needed to ungroup all the bits, then still got the frames, selected the unblock,text and autocad r14 and it now works
Problem With Newly Draw Software- Please Help !!! hubery Laser Engraving & Cutting Machines 5 03-01-2011 09:23 AM
Just IN- newly released mini CNC for DIY,hobbist user minicncmc Product Announcements & Manufacturer News 0 05-09-2009 01:55 AM
Newbie here-with newly aquired SeriesI Cameronsa Bridgeport and Hardinge Mills 4 12-27-2008 11:39 AM
First part made on my newly CNC'd X1 :) Memran Benchtop Machines 13 04-29-2007 06:48 PM
My newly repaired B&S Indicator is here! widgitmaster Calibration & Measurement 4 08-05-2006 12:03 PM
