| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hi all, I recently received a 3040 laser cutter/engraver and i'm just trying to get use to using it, and getting it to run correctly. I have aligned the mirrors as best i can (took me hours) and have managed to cut some cereal packet card with power=5, speed=35. Had a few problems with the card setting alight, but i think i've figured it out, do these settings sound alright? Now i'm trying to cut 3mm acylic. Can anybody let me know what power and speed settings they use for this? I jus can't seem to figure it out. When i get it to cut right through, the edges are kind of melted and not good. The other thing i'm worried about is that occasionally when i try to cut, there will be one line as expected, and then another fainter line engraved about 5mm away from it, anyone know what might be causing this? I am completely new to all this, so any hints and tips are welcome! Thanks guys. x |
Saw acquaintance laser cutting ( literally tons) acrylic yesterday.I asked id he use air, and he said just enough to stop it catching fire. Underside supports were made from plastic. Metal points got hot and damaged underside.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
Do you have an air assist cone on the laser head? I have seen this when the beam is not aligned correctly through the last mirror. It exits the focussing lens off-centre and reflects off the side of the air assist cone. Regards Dave. |
| When the laser beam is correctly straight, you can set the power bigger, becasue you want to cut the acrylic, you have to set the power bigger, and speed slower. ----------------------- www.roc-tech.net Last edited by roctech; 06-29-2009 at 03:46 AM. |
| dvdlock might be on the right track with this and in the same way that you put things over the mirrors to see where the beam was hitting them, you can remove the 45 degree mirror on the head (and put something in it's place) to check where that is being hit, and over the bottom end of the head (take the lens out first) to see where it's going down there. |
| Tags |
| 3040, cutting acrylic |
| Cutting Acrylic | Gujustud | Glass, Plastic and Stone | 20 | 01-27-2009 07:05 PM |
| Newbie Questions - Assembly Laser Cutting Machine | watxup | Laser Engraving & Cutting Machines | 2 | 11-01-2007 10:00 AM |
| laser cutting acrylic - art application | charper | Laser Engraving & Cutting Machines | 2 | 11-07-2006 12:50 AM |
| Cutting Acrylic | SatanKlawz | WoodWorking | 23 | 07-23-2006 01:42 AM |
| I need help about cutting heads which apply to apparel pattern cutting machine | sheepgrass | Mechanical Calculations/Engineering Design | 0 | 05-12-2006 01:09 PM |
